(49G) OEIS A084545: Counting Base 5 without Zero
08-31-2017, 03:07 PM
For integer input N the programme returns the Nth element of the sequence
https://oeis.org/A084545 NB The description below uses the expression eg Z4_ for ZINT 4. The two are however NOT the same, Z4_ having 2.5 Bytes & ZINT 4 having 6 Bytes. The size & check sum below are for the version as printed. Code: :: |
09-01-2017, 03:57 PM
RE: (49G) OEIS A084545: Counting Base 5 without Zero
A faster version of the programme:
Code: :: |
09-01-2017, 11:09 PM
If you use the standard HP extable library and 50g's built-in assembler, you can use Gerald's source code if you add the following lines to the very beginning:
Code: EQU Z1_ 273B6 <0|ɸ|0> -Joe- |
09-03-2017, 02:43 PM
But this programme is much faster & smaller:
Size: 110.5 CkSum: # 6A43h Code: :: |
09-04-2017, 07:16 PM
With that last version, I get 111.5 bytes and #DF96h, and it just hangs when I run it.
09-04-2017, 08:22 PM
(This post was last modified: 09-04-2017 08:23 PM by Gerald H.)
I have copied the published programme & compiled on 50g, programme works correctly & size 110.5 & Cksum 6A43 as published above.
Has anyone besides Eric had problems? |
09-04-2017, 09:40 PM
(This post was last modified: 09-04-2017 09:42 PM by Joe Horn.)
(09-04-2017 08:22 PM)Gerald H Wrote: I have copied the published programme & compiled on 50g, programme works correctly & size 110.5 & Cksum 6A43 as published above. It runs fine on mine, and yields the size & checksum you cited. (It fails with inputs < -4 but that might be expected). <0|ɸ|0> -Joe- |
09-05-2017, 01:08 AM
I take back what I said. This is a bug in Jazz. See my explanation on the other thread:
http://www.hpmuseum.org/forum/thread-893...l#pid78579 |
