HP-41CX - Time Module?
04-03-2014, 07:21 AM
Hi there,
So I bought a HP-41CX (Srl 2514S40570) with two broken posts. I had the vague notion, I would find a time module somewhere in the machine. Possibly, because a hack from the eighties still lurked in some dusty attic of my skull: Installing modules inside HP-41 When I opened it I found out that clearly the Time Module is integrated into the logic board. There's a quartz crystal soldered directly to the main logic board. Diego, on his Clonix page, refers to the motherboard which I found: ![]() I was not sure what to expect when I bought the CX, but I have seen at least one reference to a separate timer board in another thread here: [HP-41CL] Time Module Implant Should I be able to salvage another CX, is there any way to know beforehand, whether I'll find a separate timer board or is it necessary to open the calculator? Thanks, a.n.. |
04-03-2014, 08:33 AM
RE: HP-41CX - Time Module?
(04-03-2014 07:21 AM)anetzer Wrote: Should I be able to salvage another CX, is there any way to know beforehand, whether I'll find a separate timer board or is it necessary to open the calculator?Only halfnut CX units have a separate timer board (brigde board). A halfnut is indicated by rounded display corners. -- Ray |
04-03-2014, 10:13 AM
RE: HP-41CX - Time Module? | |||
