find the lowest common denominator
01-15-2018, 10:25 AM
hello
how can i find the lowest common denominator of two numbers with Hp prime ? thanks |
01-15-2018, 12:53 PM
RE: find the lowest common denominator
I'm not sure there is a build-in function providing the lowest common denominator.
So here is a small program doing that: Code: EXPORT LCD(N,M) |
01-15-2018, 12:59 PM
(01-15-2018 12:53 PM)Didier Lachieze Wrote: I'm not sure there is a build-in function providing the lowest common denominator. There is: it's the lcm function (lowest common multiple). In CAS, it works on integers of any length. lcm(12,18) --> 36 1/12+1/18 --> 5/36 It also works on polynomials, not just integers. <0|ΙΈ|0> -Joe- |
01-15-2018, 01:20 PM
(This post was last modified: 01-15-2018 01:21 PM by Didier Lachieze.)
Good point, I misunderstood the request as beeing for the lowest common divisor.
01-16-2018, 12:31 AM
I'm getting to go through this basic math with my kids now.
I think the least common divisor can be found with the "1" function. ;^) On the 50g, this was actually function of sort, at least a token so that this commonly used number parsed faster than a number literal. Don't know that they have done the same with the Prime. -jgs |
