HP-Prime CAS manual translated to English
01-19-2018, 04:15 PM
Hello
As an humble contribution to this forum, and since some of you recently showed their interest for this, I have translated to English the HP-Prime CAS manual from Renée de Graeve and Bernard Parisse. You will find it in the same folder as the French version: HP-Prime CAS manual in English This is so far just a "beta" version. I would be pleased that some of you could help me to improve the translation where needed, especially for the highlighted wordings (look for the mention "Translation to be checked"). For some reasons, I decided to rework the original LaTex text in Word for Mac 2011. I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? Kind regards. |
01-19-2018, 04:22 PM
RE: HP-Prime CAS manual translated to English
Very impressive, thank you!
Salvo ∫aL√0mic (IT9CLU) :: HP Prime 50g 41CX 71b 42s 39s 35s 12C 15C - DM42, DM41X - WP34s Prime Soft. Lib |
01-19-2018, 05:35 PM
(This post was last modified: 01-19-2018 05:40 PM by Tim Wessman.)
Very impressive indeed.
Since you are probably more familiar with both then I, how would you summarize the differences between the english document that is already there and the french source manual you used to create this? How significant are the differences? To be clear, I understand this is the "HP Prime CAS" manual, but how much difference is there between the "cascmd_en.pdf" and the HP Prime one? Is there huge amounts of shared content? Just trying to get a better feel for it. TW Although I work for HP, the views and opinions I post here are my own. |
01-19-2018, 06:11 PM
(01-19-2018 04:15 PM)Jean-Michel Wrote: For some reasons, I decided to rework the original LaTex text in Word for Mac 2011. I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? If you use this code in your preamble, your index, footnotes, and references turn to hyperlinks. Code:
01-19-2018, 08:56 PM
(01-19-2018 05:35 PM)Tim Wessman Wrote: Very impressive indeed. I thank you for your kind words. Bernard Parisse could answer your question much better than me. I will only say that I used cascmd_en to check my translations, at least for the common part of the text. Being longer, the text written by Renée de Graeve gives more place to examples and explanations, whereas cascmd_en looks to me more like a sort of quick reference guide. Kind regards. |
01-19-2018, 09:55 PM
(01-19-2018 06:11 PM)Michael K-K Wrote:(01-19-2018 04:15 PM)Jean-Michel Wrote: For some reasons, I decided to rework the original LaTex text in Word for Mac 2011. I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? Thank you Michael for your advice. May I kindly ask you where I should insert these lines of code? What is what you call "preamble"? I work with Word for Mac, 2011. Kind regards. |
01-19-2018, 11:21 PM
Thank you for your hard work!
Software Failure: Guru Meditation -- Antonio IU2KIY |
01-19-2018, 11:45 PM
Many, many thanks, Jean-Michel! It will be used every day. Greatly appreciated!
<0|ɸ|0> -Joe- |
01-20-2018, 09:36 AM
(01-19-2018 09:55 PM)Jean-Michel Wrote: Thank you Michael for your advice. Jean-Michel, sorry, I totally misinterpreted your first post. I thought you turned to Word because you did not manage in LaTeX to convert references to hyperlinks. The above code is LaTeX-code - totally useless to you. Unless you would like to revert to LaTeX, in this case, I could provide an empty document with a complete preamble, which is used to determine the formatting of the whole output. The preamble is that part of code before the document starts. With Word I am of no help, I avoid those word processors as much as possible. Best regards! |
01-21-2018, 07:59 AM
Really fantastic job!!!! Thank you so much! I've been waiting a while for someone to do this.
I do have a question. I noticed the last few lines of both the english and french versions have an inconsistency.....In the french version there are a few calls to PCGD() and these get converted to GCD() in the english version. Why is that? Thanks -Donald |
01-21-2018, 08:07 AM
Added to HP Prime wiki....
http://www.wiki4hp.com/doku.php?id=prime:start |
01-21-2018, 08:54 AM
many many thanks for your incredible effort
01-21-2018, 10:21 AM
It is one of the most relevant contributions to the CAS for years, the benefit for common use in the HP Prime and its programming will be significant!!
Viga C | TD | FB |
01-21-2018, 11:44 AM
(This post was last modified: 01-21-2018 12:34 PM by Jean-Michel.)
(01-21-2018 07:59 AM)webmasterpdx Wrote: Really fantastic job!!!! Thank you so much! I've been waiting a while for someone to do this. Thank you Donald for your kind words. In French: - PGCD = Plus Grand Commun Dénominateur - PPCM = Plus Petit Commun Multiple In English: - GCD = Greatest Common Denominator - LCM = Lowest Common Multiple You said you noticed the above in the "last few lines": did you already read the entire document?! Kind regards. [EDIT]: corrected greateST and loweST (instead of greateR and loweR) |
01-21-2018, 12:50 PM
LOL no, I didn't read the entire document, but I scrolled through it to make sure it was Prime related with Prime examples....and I arrived at the last page and noticed the discrepancy. Makes sense. Thx.
-D |
01-21-2018, 01:50 PM
(This post was last modified: 01-22-2018 02:36 PM by compsystems.)
Hello, sorry for my bad English
I want to make a contribution to the reference guide 1: Please include the evalb command evalb(expression) This function will evaluate expression down to a true/false or 1/0 value if possible, in terminal view returns true/false, otherwise 1/0 Examples: print(evalb(√4==2)) -> true evalb(√4==2) -> 1 2: I have seen in the document the postfix command ( :; ) but it is not documented, although in the hp-prime does not work the synonym (command type function) nodisp(), but the postfix cmd work MAKEMAT(0,30,30) [enter] returns Code: [[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0],[0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]] (MAKEMAT(0,30,30)):; [enter] returns "Done" http://www-fourier.ujf-grenoble.fr/~pari...fr076.html 3: NOP cmd: No OPeration instruction. Example: Function to expand the absolute value |2*x-1| -> 2*x-1 = 1 and -2*x+1 = 1 [subst((abs(2*x-1)) = 1,'abs','nop'), subst((abs(2*x-1)) = 1,'abs','neg')] returns [(2*x-1) = 1, (-2*x+1) = 1] ---------------- PD: Symbolic algebra and Mathematics with Xcas (Reference guide) english documentation incomplete. https://www-fourier.ujf-grenoble.fr/~par...md_en.html Calcul formel et Mathématiques avec Xcas (guide de référence) french "full" documentation. There are new commands that are not documented either. =( http://www-fourier.ujf-grenoble.fr/~pari...index.html Who wants to join the Spanish translation project? http://xcas.e.ujf-grenoble.fr/XCAS/viewt...=22&t=1797 |
01-23-2018, 12:13 AM
(01-19-2018 04:15 PM)Jean-Michel Wrote: I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? No it's not possible. People have been asking MS for this for years but they never add it. Drop the menus and introduce the ribbon bar: yep they'll do that. But add a useful feature? Not a chance. |
01-23-2018, 12:23 PM
(01-23-2018 12:13 AM)BruceH Wrote:(01-19-2018 04:15 PM)Jean-Michel Wrote: I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? Hello Bruce Thank you for this (deceiving) confirmation. This could have been a usefull feature. Kind regards. |
01-23-2018, 12:40 PM
(01-23-2018 12:13 AM)BruceH Wrote:(01-19-2018 04:15 PM)Jean-Michel Wrote: I did not find how to have the page numbers of the index as links to the document. Is this possible? If so, how? So don't do it in Word. If you create a PDF or HTML file, it's easy to do. Tom L Cui bono? |
01-23-2018, 08:12 PM
Great works!
Thank you very much!! |
