combining hp41 modules into one cartridge
02-13-2018, 02:19 AM
Greetings. Can someone point me to any documentation on shoehorning two ROM circuits into one cartridge? I recall a French article that described how careful soldering and perhaps a little sandpaper could put two 4K ROMs in one package.
Also, for someone expert in this manuever can you put an Extended Memory together w a 8K ROM because the address spaces don’t overlap?
Thanks
Todd
https://github.com/twdeckard/HP41CX-SLANTR?files=1
https://github.com/twdeckard/HP41CX-PLAN...PLAN41.rpn (doomed to
remain incomplete and undebugged)
02-13-2018, 02:32 AM (This post was last modified: 02-13-2018 02:36 AM by Mark Hardman.)
RE: combining hp41 modules into one cartridge
(02-13-2018 02:19 AM)twdeckard Wrote:  Greetings. Can someone point me to any documentation on shoehorning two ROM circuits into one cartridge? I recall a French article that described how careful soldering and perhaps a little sandpaper could put two 4K ROMs in one package.
Thanks
Todd
This thread in the old forums section would be a good place to start:
Double Extended memory module HP41cx..
PeterP references specific issues of PPC:
PPC V11N1 p28 - Procedure for Module Doubling/Tripling
PPC V13N7 p21 - Procedure for Module Doubling/Tripling
If you don't already have a copy of the PPC DVD, it can be purchased for a modest amount from Jake Schwartz at http://www.pahhc.org/ppccdrom.htm.
Ceci n'est pas une signature.
02-13-2018, 02:48 AM
I plan to do this with two extended memory modules, but I’m going to combine two single density memory modules first, so I have a better chance of success with the extended memory modules.
Try CC41!
02-13-2018, 03:47 AM
try this:
http://www.hpmuseum.org/guest/klug/dblxmem.pdf
02-13-2018, 07:49 AM
if you succeed, i would be interested in the empty module shell and connector. Smile Good luck on your project. the pdf linked by Nate Martin is probably the best starting point.
02-13-2018, 09:22 PM
(02-13-2018 07:49 AM)damaltor Wrote:  if you succeed, i would be interested in the empty module shell and connector. Smile
3D printed Module shells can be found at:
https://www.shapeways.com/product/LSV44R...-inventory
02-14-2018, 02:15 AM
Thanks!
02-14-2018, 09:09 AM
Thanks, i have seen that. Still the original shells are nicer, and the connector is hard to build from scratch Smile
