HP 15c CE - New firmware update officially available! - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: General Forum (/forum-4.html) +--- Thread: HP 15c CE - New firmware update officially available! (/thread-22078.html) |
RE: HP 15c CE - New firmware update officially available! - tommi60 - 09-04-2024 10:56 AM (08-06-2024 12:15 PM)Dave Britten Wrote: Okay, I got mine updated (that was a bit of an ordeal), but the debouncing is way too aggressive. It's basically unusable like this. Try quickly typing in 1000, and there's a good chance it will only register 100. Is there a specific byte/word in the firmware binary I can change to adjust the debounce interval? 120 ms is much too high - I suspect it needs to be about half that. For me it's the opposite, 120 ms seems to be just perfect. I have extensively tested my calculator after updating it. It just works now. Every time. As it should. From not being able to use my HP-15CE that much because of the ridiculous amount of key bounces I now have a perfectly functional calculator. That I can trust also for sensitive calculations. RE: HP 15c CE - New firmware update officially available! - eisbaer - 09-15-2024 02:04 PM (09-04-2024 10:56 AM)tommi60 Wrote: For me it's the opposite, 120 ms seems to be just perfect. I have extensively tested my calculator after updating it. It just works now. Every time. As it should.Same thing here. My 15c was useless until I ordered the cable and did the update. Haven't had a key bounce since. Quite happy with this solution. |
