New HP-41 Calculator Stand
09-08-2020, 07:37 PM
Post: #41
RE: New HP-41 Calculator Stand
(09-08-2020 06:47 PM)twoweims Wrote: I will fix that. I will ship anywhere. If not a link to your auction, may we know your eBay ID? Thanks! Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-09-2020, 12:49 AM
(This post was last modified: 09-09-2020 12:51 AM by Sylvain Cote.)
Post: #42
(09-08-2020 10:41 PM)twoweims Wrote: International shipping should be fixed now.Not quite, it is still not searchable on localized eBay's. I was able to see your account but not your listed items. But by manually changing the path I could access it and finally buy it. → https://www.ebay.ca/itm/203100535003 I choose the Faux Granite version, thanks for making them. Sylvain |
09-09-2020, 05:00 AM
(This post was last modified: 09-09-2020 05:04 AM by Sylvain Cote.)
Post: #43
RE: New HP-41 Calculator Stand | |||
09-09-2020, 12:09 PM
Post: #44
(09-09-2020 02:41 AM)twoweims Wrote: The HP-41 Stands are now on line: All sold in about 8 hours! Did I mention demand?? --Bob Prosperi |
09-10-2020, 12:38 AM
Post: #45
(09-09-2020 05:00 AM)Sylvain Cote Wrote:(09-09-2020 02:41 AM)twoweims Wrote: The HP-41 Stands are now on line:Shipping to: Worldwide That should no longer be the case! I changed that setting globally in my account. I will look into it. eBay does not make it easy to set this up... All of the 41 Stands have sold out. I have four more on the printer now they will be posted within the next couple of days. Je suis désolé. |
09-10-2020, 12:44 AM
Post: #46
(09-09-2020 12:09 PM)rprosperi Wrote:(09-09-2020 02:41 AM)twoweims Wrote: The HP-41 Stands are now on line: I am truly humbled by the response. I hope these live up to everyone's expectations. More are on the way... |
09-10-2020, 12:51 AM
Post: #47
(09-10-2020 12:38 AM)twoweims Wrote: That should no longer be the case! I changed that setting globally in my account.I understand, no problem, thank you for looking into it. (09-10-2020 12:38 AM)twoweims Wrote: All of the 41 Stands have sold out. I have four more on the printer now they will be posted within the next couple of days.Great! I will buy one. Thanks! Sylvain |
09-10-2020, 12:55 AM
Post: #48
09-10-2020, 03:07 AM
Post: #49
Hi!
Setting up my lab in the next week so I need one HP 41 stand and 1 71B stand! Let me know when they are available please. Geoff |
09-11-2020, 12:23 AM
Post: #50
How well does a 50G fit on this?
09-11-2020, 03:17 AM
Post: #51
(09-11-2020 12:23 AM)David Bengtson Wrote: How well does a 50G fit on this? Not well at all, unfortunately. The extra length, rounder bottom and relatively tiny rubber 'feet' of the 50g cause it to slide around and not stay still while using it. Also, although the angle of this stand works fine for viewing the display of the intended models (41C, Spice, DM41/42) the LCD on a 50g does not look as clear when viewed this way. I wonder if tw has a 50g... hmmm... --Bob Prosperi |
09-11-2020, 02:41 PM
Post: #52
(09-11-2020 03:17 AM)rprosperi Wrote:(09-11-2020 12:23 AM)David Bengtson Wrote: How well does a 50G fit on this? Sorry, I do not have a 50g in my collection. I do have a 48G and it definitely does not fit very well. I may re-visit more options in the future. |
09-11-2020, 02:50 PM
Post: #53
I have more 41 Stands up on eBay.
Sandstone: https://www.ebay.com/itm/203103303367 Dark Green: https://www.ebay.com/itm/203103300348 More 71B Stands are in production. There is still one available: https://www.ebay.com/itm/203100539112 I seem to have the international exclusion list sorted out. North America and Europe should no longer be excluded. |
09-11-2020, 03:24 PM
Post: #54
09-11-2020, 07:19 PM
Post: #55
Just ordered a green one.
Thanks a lot! Greetings, Massimo -+×÷ ↔ left is right and right is wrong |
09-12-2020, 09:29 PM
Post: #56
I have more 71B Stands up on eBay.
Terra Cotta: https://www.ebay.com/itm/203104264700 Dark Green: https://www.ebay.com/itm/203104268024 Terra Cotta without the rear shelf for the PIL-Box: https://www.ebay.com/itm/203104266909 There are still some 41 Stands available: Dark Green: https://www.ebay.com/itm/203103300348 Sandstone: https://www.ebay.com/itm/203103303367 |
09-12-2020, 10:12 PM
Post: #57
I see the 41 stand has changed a bit, with the 3 holes in the bottom lip (presumably to save material), and the lower lip seems a bit taller. Was this changed to accommodate the 65 & 67 machines with the raised bottom edge?
--Bob Prosperi |
09-12-2020, 10:44 PM
(This post was last modified: 09-12-2020 10:59 PM by twoweims.)
Post: #58
(09-12-2020 10:12 PM)rprosperi Wrote: I see the 41 stand has changed a bit, with the 3 holes in the bottom lip (presumably to save material), and the lower lip seems a bit taller. Was this changed to accommodate the 65 & 67 machines with the raised bottom edge? The bottom lip is the same height. The holes allow an iPhone to use the stand and not block the speakers. The center hole can accommodate the iPhone charger cable. It works for my iPhone 11 but I don't want to advertise it as such because it may not work with all sizes and versions of iPhones. I certainly don't want to attempt to play catch-up with Apple's design changes. Old -vs- New: |
09-13-2020, 06:14 PM
Post: #59
09-13-2020, 08:33 PM
Post: #60
