exponential simplification
09-23-2020, 01:16 PM
I was doing some fuse i-squared-t calculations last night and found that when you use the CAS to multiply exp(x) * exp(x) you get exp(x)^2 and not exp(2x). Is there a way to get the CAS to do that simplification?
09-23-2020, 04:46 PM
(This post was last modified: 09-23-2020 05:16 PM by ramon_ea1gth.)
RE: exponential simplification
The CAS command "lin" (from the catalog) does the work.
The "lin" command should be listed in the menu "CAS/Rewrite/Exp & Ln" from my point of view. Ramón Valladolid, Spain TI-50, Casio fx-180P, HP48GX, HP50g, HP Prime G2 |
09-28-2020, 02:01 PM
Thanks!
