HP-65 1333A21028 restoration pictures
02-14-2021, 06:28 PM
Hi everyone,
this is one of our last projects, we thought someone may find interesting the pictures, you never know, may be there are internal details that could be interesting for someone and you don't see pictured everyday We have ordered a 3M biadhesive and we will try to use it for the back label rather than the usual spray glue in future we will start to repair the rest of our pieces, so there will be more to see and we will have more to ask thanks for all the support provided, take care and stay safe !! Pictures can be seen here : HP-65 1333A21028 restoration pictures Edoardo & Alberto |
02-14-2021, 11:51 PM
RE: HP-65 1333A21028 restoration pictures
(02-14-2021 06:28 PM)albertofenini Wrote: Hi everyone, Which 3M adhesive? Can you post how effective it is, especially if the label has to be removed again :-) cheers Tony |
02-15-2021, 12:53 AM
Hi Tony
it should be here on Wednesday It’s 0,2 mm thick and 38 mm high so that it will be a single piece for each label We usually leave it in a grip overnight Instructions claims this is very strong so will see it and we will update the post Take care !!! (02-14-2021 11:51 PM)teenix Wrote:(02-14-2021 06:28 PM)albertofenini Wrote: Hi everyone, Edoardo & Alberto |
02-15-2021, 01:25 AM
(This post was last modified: 02-15-2021 01:26 AM by teenix.)
(02-15-2021 12:53 AM)albertofenini Wrote: Hi Tony Thanks. I was thinking of photo adhesive which allows photos to stick, but can be peeled off if required. I haven't tried it, but I thought using it on back labels, they might stay put but come off easily if required. cheers Tony |
02-16-2021, 08:48 PM
(This post was last modified: 02-16-2021 08:50 PM by albertofenini.)
Here we go !
The tape arrived today It is 38 mm high which means that for an HP65 or HP67 only a single piece is needed This is good because it is more efficient We have cut a piece of plastic the exact size of the “tray” where the label goes This is needed when we put the chassis under pressure overnight On the inside two water bottle caps help to distribute pressure in an homogeneous way The assembly is then put between two pieces of wood for the night 3M claims that best results are obtained if the temperature is between 40 and 50 Celsius degree We skipped that part ... so will see tomorrow morning We first have put the tape on the calc Using an exacto knife the adhesive has been cut to the exact size Then label applied using the plastic shape and some soft cotton an homogeneous pressure have applied It doesn’t look bad at all but the last word can only be said tomorrow Pictures can be seen here : HP65 LABEL WITH 3M ADHESIVE Let us know what you think If you like I can post the Amazon link to this tape Edoardo & Alberto |
02-17-2021, 12:36 AM
Thanks for sharing these detailed photos and your nice step-by-step explanation. I've wondered about using this kind of adhesive so I look forward to seeing the final results.
It looks like you have enough adhesive for quite a few repairs... --Bob Prosperi |
02-17-2021, 09:42 AM
you are right ... but we have few units to re-label as well
(02-17-2021 12:36 AM)rprosperi Wrote: Thanks for sharing these detailed photos and your nice step-by-step explanation. I've wondered about using this kind of adhesive so I look forward to seeing the final results. Edoardo & Alberto |
02-17-2021, 08:37 PM
RE: HP-65 1333A21028 back label (was restoration pictures)
Hi everyone
A night and a day have passed and this is the final result It’s pretty awesome although it must said that the label was in very good condition Compared with the spray glue this method is easier and cleaner We think is probably easier to remove the label if ever needed again Now we must see how reliable and long lasting is going to be It would be better to heat the surface up to 50 Celsius degrees in order to catalyze the glue The four last added picture show the final result HP65 back label with 3M adhesive - final results Thanks everyone for the support and take care !!! Edoardo & Alberto |
