New beta 22 April
04-22-2021, 02:51 PM
New beta 22 April
A new version of the beta should be available in the next couple of hours (once Eric can put it online) at http://www.hpcalc.org/prime/beta/ Here is the change log. Have a great WE! Cyrille NEW FEATURE: add proot wizard FIXED BUG: add degree of freedon in chi² GOF test FIXED BUG: solve app, cancel an equation entry with new var caused an error FIXED BUG: cos(0.5*pi) now returns 0 in home FIXED BUG: paste of a quoted " did not work FIXED BUG: in cas view, toolbox/cas/functions yeilded CAS.function() FIXED BUG: e^24 a b/c yeilded wrong results... This hit the limit of the fraction algo... I have limited fractions to exponent 8 to avoid such issues. FIXED BUG: problem in program encryption FIXED BUG: in debuging, watching non existing local variable resulted in crash FIXED BUG: USBOpen now returns all valid vid/pids to use... FIXED BUG: print and print2D replace tab by spaces... FIXED BUG: window draging through the main calcualtor image does not shift anymore FIXED BUG: python switching from num to symb caused unnessecary "do you want to reimport" FIXED BUG: python input with user using the +/- key yeilded a HP minus sign. Was replaced by a real '-' FIXED BUG: python round(3/7,6) yeilded an incorrect result FIXED BUG: python prime call to rgb returned wrong value FIXED BUG: python app ON stops a program now FIXED BUG: python keyboard was reversing data byte per byte FIXED BUG: some keys provided the wront text in Python FIXED BUG: switching from python symb to num yeilded continious messages... Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-22-2021, 04:42 PM
RE: New beta 22 April
Many thanks. Looking forward to getting stuck in again.
04-22-2021, 04:46 PM
Upgrading G1 & G2, thanks for the efforts Cyrille.
Love to see the Prime developing further |
04-22-2021, 05:14 PM
(This post was last modified: 04-22-2021 05:21 PM by calc_freak.)
Connectivity Kit - Check
Virtual Prime - Check G2 Prime - Check G1 Prime - bricked (Stuck on X^2 + Y^2 = 1 screen, Conn Kit says no calculator connected, repeated resets return it to the stuck screen) Edit: even a full reset with format of drive C, and I'm not alone as the next post indicates |
Not sure if this is just me, but after updating G1 it's stuck with the startup eq logo screen (x^2+y^2=1). I'll go back to last firmware.
04-22-2021, 05:30 PM
I should have checked here before flashing my G1. Yep, bricked here too.
04-22-2021, 05:34 PM
Yeah I got stuck on the formula screen on my G1 too. I reverted back to the April 16th beta via recovery mode.
-Dream of Omnimaga https://dreamofomnimaga.page |
Having the same issue of G1 stuck at x^2+y^2=1 for two different ver A's.
Both were able to go into recovery mode and I was able to downgrade back to their previous versions. |
04-22-2021, 05:35 PM
And they have pulled the update.
Now, what do us early adopters do to remedy the situation? |
04-22-2021, 06:27 PM
(This post was last modified: 04-22-2021 06:28 PM by ggauny@live.fr.)
Here too, stuck on formula screen! on G1 Gérard. |
04-22-2021, 06:34 PM
(04-22-2021 05:35 PM)calc_freak Wrote: And they have pulled the update. I'm sure they're working on it. You'll have to wait until the fixed version is ready. They're very responsive so I wouldn't think it would be too long before the fixed G1 beta is up. Tom L Cui bono? |
04-22-2021, 06:41 PM
(04-22-2021 06:34 PM)toml_12953 Wrote:(04-22-2021 05:35 PM)calc_freak Wrote: And they have pulled the update. My concern is that my G1 is bricked solid. None of the usual fixes work - recovery mode goes right back to the stuck screen, and it never shows up as connected on the Connectivity Kit software. Oh well, live and learn - sometimes beta testing is really alpha testing. LOL |
04-22-2021, 06:42 PM
oh no!, they took my toy!
I will have to buy an HP Prime G2 now, of course, there is no other choice. |
04-22-2021, 06:45 PM
(04-22-2021 06:41 PM)calc_freak Wrote:(04-22-2021 06:34 PM)toml_12953 Wrote: I'm sure they're working on it. You'll have to wait until the fixed version is ready. They're very responsive so I wouldn't think it would be too long before the fixed G1 beta is up. If you reset while pressing symb, hp Connectivity kit should detect the prime in recovery mode (at leas mine did). That being said, i still have not tried to go back to previous firmware (still at work). |
(04-22-2021 05:34 PM)Wes Loewer Wrote: Having the same issue of G1 stuck at x^2+y^2=1 for two different ver A's. You can enable recovery mode by holding down Symb while doing a paper clip reset. Once you are in recovery mode, then after a little while the Connectivity Kit should detect it and offer to upgrade firmware. If it doesn't detect it, try unplugging and replugging in the usb. |
04-22-2021, 06:48 PM
(04-22-2021 06:45 PM)josolla Wrote:(04-22-2021 06:41 PM)calc_freak Wrote: My concern is that my G1 is bricked solid. None of the usual fixes work - recovery mode goes right back to the stuck screen, and it never shows up as connected on the Connectivity Kit software. Oh well, live and learn - sometimes beta testing is really alpha testing. LOL I hereby award you 10 internets! Thanks for the tip - it worked. |
04-22-2021, 06:52 PM
(This post was last modified: 04-22-2021 06:53 PM by BruceH.)
(04-22-2021 05:35 PM)calc_freak Wrote: And they have pulled the update. You should try paperclip reset etc. first but if you're really stuck then this post might help. https://www.hpmuseum.org/forum/thread-11...#pid102736 Edit: beaten to it by Wes while I was trying to find that post. :-) |
(04-22-2021 06:45 PM)Wes Loewer Wrote:(04-22-2021 05:34 PM)Wes Loewer Wrote: Having the same issue of G1 stuck at x^2+y^2=1 for two different ver A's. You, sir, also are awarded 10 internets. Many thanks for the reply. |
04-22-2021, 07:21 PM
(04-22-2021 02:51 PM)cyrille de brébisson Wrote: NEW FEATURE: add proot wizard I love the new Probability Wizard and was pleased to see that now there is a new proot wizard, but I think I'm missing something. A Wizard usually does something in a more interactive manner which is great for students, but this one seems to be even more cumbersome than the command line process. Here are some suggestions that would make it much more usable.
04-22-2021, 07:41 PM
Hi Cyrille,
Many many thanks for this revival of HP ! Much appreciated. I'm particularly interested in the Python editor. Just a few questions: 1/(bug) It seems that the "Indent" check has no effect, even if today's build: every new line starts at the left-end, which is ennoying. 2/(feature) Is it planned to auto-indend (shifting the line after ":" on the previous line) ? 3/(features) Is it planned to implement color syntax highlighting and auto-completion ? Would be great. Thanks and cheers, Vincent |
