DIMGROB back from Graphics Variable?
05-24-2021, 09:24 PM
Is there a way to get a DIMGROB from a G1 Graphic Variable, so that I can include it in a program, instead of having to transport the .png file from which the G1 is created with the program, for another person to try out?
So if G1 is defined on a HP Prime, is there a way to get a DIMGROB from the calc? |
05-26-2021, 10:07 PM
(This post was last modified: 05-26-2021 10:32 PM by matalog.)
RE: DIMGROB back from Graphics Variable?
I found a way to do it, but it will obviously require a large amount of space in the program, it works though, and can be used to put sprites into a program and not need to send any files along with the program.
Code: EXPORT NH() This saves the colours of the 'sprite' or graphic which can be loaded as a PNG, to a notes file called COL, which can be viewed on computer, and then pasted as a DIMGROB, and therefore entered into a program. |
