Is it possible to increase the stack/heap size for native Python(not in CAS)?
06-07-2021, 05:11 AM
First, many thanks to HP calculator team for the great upgrade!
I've been working on the brand new native Python for a couple of days, tested same Mandelbrot code(almost) on both HP Prime G2 and TI Nspire CX II CAS, G2 is insanely faster(nearly 5 hundreds times)!
When I was trying to implement a Game Of Life, I defined an array of more than 320x240x2 elements, I got an error complaining it was over the size of stack.
I searched this forum and got a solution for CAS Python, like:
#python("name",stackSize,heapSize)
I tried in native Python, but unfortunately not working.
Could somebody figure me out how to resize the stack?
Thanks in advance!
06-07-2021, 01:26 PM
RE: Is it possible to increase the stack/heap size for native Python(not in CAS)?
There is a heap/stack settings if you do
Shift Plot
06-07-2021, 02:45 PM
Thank you very much, Dougggg!
Shift+Plot means “Setup”, I can set either size of them, and can also check the size of available memory, so convenient!
