x Theta x or a
06-09-2022, 11:20 AM
x Theta x or a
Can someone clear this up for me:
When entering equations into the solver both in CAS and No-CAS mode I seem to be getting only "a" when I press the x theta key. I know there are times when the key provides an "x" when it is pressed. When should I expect an "a" and when should I expect to see an "x" when x Theta key is pressed? Thanks in Advance -Tim C. |
06-09-2022, 01:23 PM
RE: x Theta x or a
It depends on what app is active. In the polar app you get theta, in the geometry app you get x, it the parametric app you get a t, etc.
-road |
