Earth to Mars trajectory design
10-01-2022, 10:26 AM
This HP program can be used to calculate ballistic interplanetary trajectories between the Earth and Mars. The orbit transfer is modelled as a two-body system with an impulsive delta-v at departure and arrival.
The user can provide an Earth departure calendar date and a Mars arrival calendar date. The following is the "hard-wired" data for the attached example. // departure calendar date month := 6; day := 1; year := 2003; // departure utc julian day jd_depart := julian(month, day, year); // earth is the departure planet ip_depart := 3; sv_depart := planet(ip_depart, jd_depart); for i from 1 to 6 do oev_depart(i) := sv_depart(i + 6); end; // arrival calendar date month := 12; day := 27; year := 2003; // arrival utc julian day jd_arrive := julian(month, day, year); // mars is the arrival planet ip_arrive := 4; sv_arrive := planet(ip_arrive, jd_arrive); |
