SY-41CL current status
09-25-2023, 06:58 PM
The current status of the 41CL project dates back to 06/02/2023, and it appears that Monte is not responding to emails. Does anyone have information on this?
Best Juergen |
09-25-2023, 08:00 PM
RE: SY-41CL current status
You have a PM.
Sylvain Côté |
10-23-2023, 02:32 PM
is it possible to get the version of the CL board i have? Without opening the calc. V1, V2, V3, V4 or V5? I bought a used CL board, but the seller didn't know anything about it. Happy programming Ralf /41/48/ |
10-23-2023, 03:46 PM
(This post was last modified: 10-24-2023 12:27 PM by Sylvain Cote.)
Generic procedure, adjust as needed for your configuration
Code: MMUDIS // disable MMU Flash device code (more info in 41CL Update Functions manual) Code: 0x22C4 V2 "top" Note: if your board is very old, the YUPS will not be available, first test the above procedure and if the ROM image is not there, I will give you more information. edit: typo Sylvain Côté |
10-24-2023, 12:23 PM
Hi Sylvain,
thanks a lot that works and shows a 0x227E, so I have a V5,. Ralf /41/48/ |
