x48ng, a x48 « restomod »
10-29-2023, 10:02 AM (This post was last modified: 10-31-2023 09:34 AM by gwh.)
Hi everyone,
Let me present to you x48ng
I've been working on a fork of x48 for some time now. This fork aims at modernizing the code and the user interface.
I think I have arrived at a state where I've made significant changes (which I think of as improvements) and departed enough from legacy x48 that a proper introduction here makes sense.
The main changes are:
  • Code:
    --tui
    a text mode interface. Using ncurses and unicode the LCD can be displayed in the terminal, in three sizes.
  • an complete rethink of the command-line options and configuration file
  • …many more small things
The Readme has more details and screenshots.
This is for me a pure hobby project, on which I work mainly in bursts of inspiration for the pleasure of it.
Hopefully it's useful to some of you. Have a good day.
EDIT: a « screenshot »:
└─[ wire: /dev/pts/3 ]-[ IR: (null) ]──────────────────────────────┘
"My" emulators: x49gpng & more
10-29-2023, 11:46 AM
RE: x48ng, a x48 « restomod »
Glad to see x48 being worked on, I kept installing it over the years on my Linux systems as I upgraded them. Thanks!
10-29-2023, 06:03 PM (This post was last modified: 10-29-2023 06:05 PM by EugeneNine.)
I've been using x48 for forever also.
I like the idea of a terminal mode
something with lua, what version of lua do you have/use?
bash-5.1$ make WITH_X11=no WITH_SDL=no
cc -g -O2 -I./src/ -D_GNU_SOURCE=1 -DVERSION_MAJOR=0 -DVERSION_MINOR=33 -DPATCHLEVEL=0  -D_DEFAULT_SOURCE -D_XOPEN_SOURCE=600 -D_DEFAULT_SOURCE -D_XOPEN_SOURCE=600 -DNCURSES_WIDECHAR=1   -c -o src/runtime_options.o src/runtime_options.c
src/runtime_options.c: In function ‘config_read’:
src/runtime_options.c:118:10: warning: implicit declaration of function ‘luaL_loadfilex’; did you mean ‘luaL_loadfile’? [-Wimplicit-function-declaration]
  118 |     rc = luaL_loadfilex( config_lua_values, filename, "t" );
      |          luaL_loadfile
src/runtime_options.c:119:16: error: ‘LUA_OK’ undeclared (first use in this function); did you mean ‘LUA_QL’?
  119 |     if ( rc != LUA_OK ) {
      |                LUA_QL
src/runtime_options.c:119:16: note: each undeclared identifier is reported only once for each function it appears in
make: *** [<builtin>: src/runtime_options.o] Error 1
bash-5.1$
10-29-2023, 07:22 PM (This post was last modified: 10-29-2023 07:40 PM by gwh.)
(10-29-2023 06:03 PM)EugeneNine Wrote:  I've been using x48 for forever also.
      |          luaL_loadfile
      |                LUA_QL
bash-5.1$
Here I have lua 5.4.6
EDIT: I just pushed a commit to the main branch that might solve your two errors. I can't really test quickly with an older lua (I suspect you have 5.1.x) but I hope it works for you.
10-31-2023, 07:00 PM (This post was last modified: 10-31-2023 07:01 PM by EugeneNine.)
Yes, I have the old 5.1
I miss the old C64 ACSII (petscii) where we had characters that were 1/4 size so we could make tui smaller Smile
here is a pic of old and new side by side Smile
11-02-2023, 09:16 AM
(10-31-2023 07:00 PM)EugeneNine Wrote:  Yes, I have the old 5.1
Thank you for your helpful feedback.
Have you tried x48ng --tui --small or x48ng --tui --tiny --mono ?
Both variants use unicode characters to display multiple pixels per character.
11-03-2023, 12:30 AM
Ahh yes, I failed to RTFM.
Works on arm, this is on a BeagleBone Black
06-09-2024, 01:01 PM
To get some more experience on historic 48+ calcs I tried to use Emu48 and x49gp.
But finally I was glad to have found x48ng, because e.g. I have tinkered around how to get a proper resolution of the X application x49gp on wayland compositor running PCs (although for Emu48 and wine not a problem ...)
With x48ng it worked to get a usable emulator with easy setup of roms, and readability on a high res screen. (FYI on arch I had to install sdl_gfx for compilation.)
This call works to get a scaled window:
SDL_VIDEODRIVER=wayland x48ng --sdl
06-12-2024, 09:02 AM
(06-09-2024 01:01 PM)raprism Wrote:  To get some more experience on historic 48+ calcs I tried to use Emu48 and x49gp.
It's encouraging to see my project be useful out there, thank you.
Regarding Arch, another kind user is maintaining packages https://aur.archlinux.org/packages/x48ng (and bleeding edge https://aur.archlinux.org/packages/x48ng-git too)
I'm very glad you find it useful!
