NoV-64D and HEPAX Questions
04-08-2024, 01:27 AM
RE: NoV-64D and HEPAX Questions
Diego & Sylvan,
My NoV-64D is currently in Miami on its way here.
In the mean time I am testing with clonixconfig v6.1 and I have the following questions so far:
1. How do I save a configuration to the PC for later modification before downloading to the NoV-64D?
2. In conjunction with #1, how do I load the saved configuration.
3. Even though I unchecked HEPAX when I clicked on proceed, clonixconfig compiled the HEPX1H-0 through 3 files (according to the mpasm log file). Why would it do this if I deselected HEPAX.
4. Does clonixconfig convert the .ROM files to .asm files and then assembles and links them into the ROM Image?
04-08-2024, 11:51 AM (This post was last modified: 04-08-2024 05:53 PM by Sylvain Cote.)
(04-08-2024 01:27 AM)BitWiz Wrote:  1. How do I save a configuration to the PC for later modification before downloading to the NoV-64D?
Unfortunately, ClonixConfig cannot save and/or restore a module configuration. Sad
(04-08-2024 01:27 AM)BitWiz Wrote:  3. Even though I unchecked HEPAX when I clicked on proceed, clonixconfig compiled the HEPX1H-0 through 3 files (according to the mpasm log file). Why would it do this if I deselected HEPAX.
I am letting Diego answering that part.
Sylvain Côté
04-11-2024, 10:01 PM (This post was last modified: 04-11-2024 11:32 PM by BitWiz.)
Sylvain and everyone else following this thread.
Thank you all for your help. I think I have it nailed down for my initial load.
See the attached file for what I have figured out.
I am still looking for recommendations for good ROMS to use and play with.
Thank you,
Mike
Attached File(s)
.pdf  HP-41_Setup.pdf (Size: 109.7 KB / Downloads: 8)
04-11-2024, 11:47 PM
I am not home, I wiil validate your config later.
Do not forget to check for XROM conflict.
Sylvain Côté
04-12-2024, 12:45 AM
Thank you. I had forgotten about that.
04-12-2024, 01:17 AM
(04-11-2024 11:47 PM)Sylvain Cote Wrote:  I am not home, I wiil validate your config later.
There are two XROM conflicts in my setup:
1. ZENROM and NOV CHAP ROM
I found the source code for this ROM in an XLS file. As soon as I learn how to compile the M-Code
XLS into a ROM file I can change the XROM number.
2. AMC_OS/X+ and HP-16C ROM. I am unable to find the source for either of these though I might
just not be looking in the right place.
I have attached a copy of the updated configuration file.
Thank you again,
mike
Attached File(s)
.pdf  HP-41_Setup.pdf (Size: 113.08 KB / Downloads: 15)
