HP67 PCB connector pins
05-08-2024, 07:02 AM
I have a HP67 and 3 PCB connectors between the KBD and CPU board has been broken. Is there a way to find replacement for this pins? I have removed 3 pins from the pcbsense board and replaced the broken ones with those but now the pcbsense board needs those pins. What else could be used to replace those? Thanks Istvan |
05-08-2024, 01:10 PM
RE: HP67 PCB connector pins
hi,
you can solder a small cable or make your own connection with a post connector or pcb connector. 2.54 mm pitch would fit. I use them for replacing broken ribbon cables as well. I can dig into my cellar and search for some pins. And if I am sucessful I can send them free of any charge to you. Ralf /41/48/ |
05-08-2024, 01:52 PM
Thank you Hiwi!
I am certanly looking for a solution but if you would happen to find those pins that would be great! I have been thinking to use a modern connector for the PCBsense board and remove those left 7 legacy style pins. Just the height of the connector must match. Let me know if you find anything. Thanks, I appreciate your help! Istvan (05-08-2024 01:10 PM)Hiwi Wrote: hi, |
05-14-2024, 02:42 PM
I have found a HP97 board, they are the same, i suppose.
Ralf /41/48/ |
05-14-2024, 02:55 PM
Hi Hiwi,
Yes, they have the same PCB connector pins. If you could desolder 3 of those and send to me that would be great! I can PM you my address. Thanks Istvan |
05-17-2024, 01:32 PM
4 are on the way to you.
Ralf /41/48/ |
05-17-2024, 03:35 PM
Thank you Hiwi!
I appreciate it! Istvan |
