Sharp PC-E500 to PC link issues
07-21-2024, 02:25 PM
(This post was last modified: 07-21-2024 02:27 PM by fy789.)
I bought the RS232C-to-USB cable from tmfg.jp to facilitate file transfer from PC to Sharp PC-E500. I follow the instruction on their website to transfer a file from PC to the E500: 1. First, I connect the cable to the PC and the E500 (Drivers on the PC side are preloaded) 2. Then I set up the E500 port by using OPEN "9600,N,8,1,A,L,&H1A,N,S":CLOSE 3. Then I put the E500 into RECEIVE mode: LOAD However, after the "LOAD" command, the E500 always return "I/O error". Is this ok? The E500 is supposed to sit there waiting for the bitstream to come in. I have read thru quite a few discussions here as well as a few other places, and there are a lot of info. (i) logic inversion of 4 flow control signals (the FTDI chip manufacturer has a configure tool to do this, but it has not been updated to run on Win10 or Win11). Is this necessary? (ii) I assume the FTDI chip will do the voltage level conversion. BTW, I appreciate if anybody successfully doing this before can post a cheatsheet to walk thru the steps and the tools used (TeraTerm, HTerm, PC-E500-Notepad....etc) ? Thanks! |
07-21-2024, 08:52 PM
RE: Sharp PC-E500 to PC link issues
(07-21-2024 02:25 PM)fy789 Wrote: Hi all, Is the CLOSE really necessary? Have you tried it without the CLOSE? Tom L Cui bono? |
07-21-2024, 09:25 PM
I don’t have this cable, but a DIY interface made with a genuine FTDI chip, that works identically on Windows 7 and 11.
On the SHARP, the parameters I use are: OPEN "9600, N, 8, 1, A, L, &1A, N, N": CLOSE This has to be done only once, as the parameters are registered afterward. I use Hterm, with the following settings: Port: must be checked in the Windows Device Manager Baud: 9600 Data: 8 Stop: 1 Parity: none CTS flow control: ON ASCII: ON RTS: ON (below the "Recieved Data" window) Then to load a program: Sharp: LOAD "COM:" Hterm: Connect - Send File… Start To save a program: Sharp: SAVE "COM:" Hterm: Connect - Save Output To exchange ASCII files, the command on the Sharp is: COPY "COM:" TO "E:filename" or COPY "E:filename" TO "COM:" This is MY cheat sheet. Jean-Charles |
07-22-2024, 02:46 AM
(This post was last modified: 07-22-2024 03:56 AM by fy789.)
Hi Jean-Charles,
Thanks for the cheatsheet! I think there is a typo on the OPEN statement: "&1A" should be "&H1A" for hexadecimal. May I know if you used the VCP or D2xxx driver to enable the port? BTW, I follow your instruction, but I still get the same "I/O error" after "LOAD COM:" I tried it on another similar machine, PC-E650, and I got the same error. The cable may be the issue. Could you show me how to construct the cable? Where did you purchase the 15-pin header connector ? Any hint? Was the I/O port toasted? Thanks! HTerm and Device Driver screen captures: https://ibb.co/6R98gNn https://ibb.co/D7Khh92 (07-21-2024 09:25 PM)Helix Wrote: I don’t have this cable, but a DIY interface made with a genuine FTDI chip, that works identically on Windows 7 and 11. |
07-22-2024, 02:50 AM
The LOAD command will automatically open the port when it is invoked;
this is documented in the PC-E500 operation manual. (07-21-2024 08:52 PM)toml_12953 Wrote:(07-21-2024 02:25 PM)fy789 Wrote: Hi all, |
07-22-2024, 11:32 PM
(07-22-2024 02:46 AM)fy789 Wrote: I think there is a typo on the OPEN statement: "&1A" should be "&H1A" for Hexadecimal numbers are valid without the H letter. This is not mentioned in the manual. Quote:May I know if you used the VCP or D2xxx driver to enable the port? With Windows 11, I had nothing to install! For Windows 7, I don’t remember the driver, but I’ve found in my archives two files named CP210xVCPInstaller_x86.exe and CP210xVCPInstaller_x86.exe, so I suppose it’s VCP. Quote:BTW, I follow your instruction, but I still get the same "I/O error" after "LOAD COM:" I don’t know this I/O error. You will find a picture of my cable here, some explanations here, and a more complete PDF document. The 1.27 mm pitch connectors are not easy to find, and certainly not easy to solder, so I managed to make my own connector with thin cables and some glue. Another difficulty is to find a genuine FTDI chip, because there are many fake chips that work correctly, but whose signals can’t be inverted. Quote:HTerm and Device Driver screen captures: In your Hterm settings, try to enable the RTS box. example Also, the port is visible in the "Port (COM & LPT)" line, not the USB line. example Jean-Charles |
07-24-2024, 02:54 PM
(This post was last modified: 07-24-2024 11:58 PM by fy789.)
I contacted the staff at the manufacturer, tmfg.jp, and after multiple rounds of correspondence, apparently they forgot to program the logic
inversion of the 4 flow-control signals. They send me the instructions to do the flash programming and it works afterwards. Now, I can use "LOAD" without any issue afterwards for transferring a BASIC games into the E500S successfully. (ASCII file) Thanks to all who tried to help! |
