(41CV) Calculator Programs for Pipe Stress Engineering
08-08-2024, 11:29 AM (This post was last modified: 08-08-2024 11:34 AM by SlideRule.)
An excerpt from Calculator Programs for Pipe Stress Engineering, Wiley © 1986, 403 pages
Table of Contents
Part I      PIPING FLEXIBILITY
Chapter 1 Elastic Center pipe stress analysis:
    TI-59-1
    HP-41CV-1
Chapter 2. The need for thrust blocks in buried Thermoelastic Resin pipe:
    TI-59-2
    HP-41CV-2
Chapter 3. First natural frequency for three distinct piping layouts:
    TI-59-3
    HP-41CV-3
Chapter 4. Flexibility factors, virtual lengths and intensification factors:
    TI-59-4
    HP-41CV-4
Part II     PIPE STRESS
Chapter5. Flanged connection bolt tensioning:
    TI-59-5
    HP-41CV-5
Chapter6. Fillet weld sizing:
    HP-41CV-6 (only)
Chapter. 7 Shell stresses from externally applied loads on welded attachments:
    TI-59-7
    HP-41CV-7
Chapter 8 Allowable pipeway spans for steel pipe:
    TI-59-8
    HP-41CV-8
Chapter 9. Support ring stresses:
    TI-59-9
    HP-41CV-9
Part III    INTERNAL PRESSURE
Chapter 10. Pressure reinforcing pads per ASME/ANSI B31.3:
    TI-59-10
    HP-41CV-10
Chapter 11.
    TI-59-11.1 Maximum allowable working pressure
    TI-59-11.2 Minimum pipe wall thickness based on internal pressure
    TI-59-11.3 Pipe- wall thickness class array for seamless and plate-fabricated pipe
    HP-41CV-11 Pipe wall thickness by class and single OD, and maximum allowable working pressure
Part IV    SPECIAL APPLICATIONS
Chapter 12 Turbo-machinery loading analysis per NEMA SM-23 and API-617:
    TI-59-12
    HP-41CV-12
Chapter 13. Buried concrete thrust block sizing in cohesionless soils:
    TI-59-13
    HP-41CV-13
Bibliography
BEST!
SlideRule
