Just Curious
09-17-2024, 12:16 AM
Just Curious
If anyone knows, just curious what this device does for the 97. It looks like it is a Scientec Calculator Interface. cheers Tony |
09-17-2024, 01:23 AM
RE: Just Curious
I am not sure but it may be related to the HP-97S model.
https://www.hpmuseum.org/hp97s.htm |
09-17-2024, 02:40 AM
(This post was last modified: 09-17-2024 02:48 AM by Sylvain Cote.)
RE: Just Curious
(09-17-2024 01:23 AM)Steve Simpkin Wrote: I am not sure but it may be related to the HP-97S model.Yep! It is a 97S, but I have no clue as to what the connected device does. Sylvain Côté |
09-17-2024, 02:58 AM
(This post was last modified: 09-17-2024 02:59 AM by teenix.)
RE: Just Curious
Oh I see, it looks like the device allows the 97 pictured to be used like a 97S.
The rear cable is likely soldered to the bus expansion connector on the CPU board. cheers Tony |
09-17-2024, 03:24 AM
RE: Just Curious | |||
09-17-2024, 12:13 PM
RE: Just Curious
I disagree, it's not a true 97S - note that the label on it says "97" and not "97S", so it's more likely some kind of DIY (back then called home-built) equivalent of a 97S, that brings a bunch of internal signals out into the box which has a connector of the back to connect to... whatever.
It's been listed for a few weeks with a steadily declining price, and although I am curious about it, I'm not $200+ curious, as it looks like it's had a tough life and would need much TLC to get it fully working only then to have no idea how to check the interface. --Bob Prosperi |
09-17-2024, 01:27 PM
RE: Just Curious
I believe the manufacturer is still in business.
Maybe they would have some documentation? -J |
09-17-2024, 03:09 PM
RE: Just Curious
Let's find out what this interface is...
I just bought the unit and will keep you updated. Matthias |
09-17-2024, 06:01 PM
09-17-2024, 06:59 PM
RE: Just Curious
[quote='Dave Frederickson' pid='191837' dateline='1726596109
From the photos, its a Model 202 Calculator Interface from Scientech in Boulder, Colorado. They're open 'til 4 PM. [/quote] I guess being that they are in Boulder, they want to be out of the office by 4:20! B^) 10B, 10BII, 12C, 14B, 15C, 16C, 17B, 18C, 19BII, 20b, 22, 29C, 35, 38G, 39G, 41CV, 48G, 97 |
