HP41 TULIP4041 update
09-25-2024, 11:07 AM
RE: HP41 TULIP4041 update
Hallo all
The PCB's for the Development Board have arrived and I have assembled and tested one unit with both the 'old' Pico board and the new Pico2, and everything seems to be working fine. This means that these PCB's are now ready to be shipped. I will send a message to all who have expressed their interest about payment. There is extra stock, so please let me know if you are also interested. After doing some more testing with the Pico2 board, I have decided to do the switch to the new RP2350 processor on the following grounds:
Regards, Meindert |
09-28-2024, 01:17 PM
Hi Sylvain,
I'm securing the TULIP4041 BOM before the board arrives. Could you tell me the spacing of the pinstrip you used ? 5mm ? 3.5mm ? or another spacing ? Maybe I missed something but I could not ascertain this information from the documentation. Thank you. Etienne (08-24-2024 02:12 AM)Sylvain Cote Wrote: The board was delivered last week and the final assembly was completed early this week. |
09-28-2024, 01:32 PM
Based on the Pico pitch and the picture of the board, my guess is 2,54mm spacing.
But just wanted to confirm Etienne |
09-28-2024, 02:20 PM
(This post was last modified: 09-28-2024 03:41 PM by MeindertKuipers.)
(09-28-2024 01:32 PM)Etienne Victoria Wrote: Based on the Pico pitch and the picture of the board, my guess is 2,54mm spacing. Correct, pitch for all connectors is 2.54mm. [edit, added] BOM file on git repo updated with connector pitch. Regards, Meindert |
10-07-2024, 04:35 PM
(This post was last modified: 10-07-2024 04:36 PM by floppy.)
(08-24-2024 02:12 AM)Sylvain Cote Wrote: Pyilper on a PI4? interesting. And on PI2 or PI3? they are much cheaper ILPER on PI2..PI4 is fine https://www.hpmuseum.org/forum/thread-19053.html HP71B 4TH/ASM/Multimod, HP41CV/X/Y & Nov64d, PILBOX, HP-IL 821.62A & 64A & 66A, Deb11 64b-PC & PI2 3 4 w/ ILPER, VIDEO80, V41 & EMU71, DM41X |
10-08-2024, 11:20 AM
The idea of using an RP4 was also to have the development tools for the Pico/Pico2 available with sufficient performance, plus some performance on the RP4 is good to have when using the terminal emulators. Especially the trace window needs to process a lot af USB data.
You are correct that when using only pyILPer a limited performance platform can be used. Regards, Meindert |
10-09-2024, 11:28 AM
The TULIP Development PCB's have been shipped today to those who had them pre-ordered and paid. I still have board sets available for those interested. Just send me a PM or email in case you are interested.
Regards, Meindert |
10-12-2024, 11:46 AM
Due to a copy/paste mistake there was an error in the TULIP DevBoard Bill Of Material. This is now fixed on the GitHub page https://github.com/mjakuipers/TULIP-DevBoard. The PWO pulldown R6 must have a value of 200K instead of 270R. I have also added the component references.
Regards, Meindert |
10-15-2024, 05:56 PM
Hello Meindert,
The two TULIP Development PCB's has been delivered today. Seven days of travel time from The Netherlands to Canada, including a holiday weekend, surprisingly fast. Thanks! Sylvain Sylvain Côté |
10-15-2024, 06:22 PM
Same quick delivery here in France. Cute PCB ! Thanks Meindert ! Awaiting the Pico 2 to start my first soldering job for a 41 since the SD-IL mass storage. Etienne |
10-16-2024, 07:18 AM
(This post was last modified: 10-16-2024 07:18 AM by MeindertKuipers.)
Good luck building it, and let me know how it goes. Most of the orders are now on their way or have already arrived. For the Pico2, just pick the right webshop, after the initial wait I had no issues getting my hands on multiple units.
Remember that I do NOT recommend to solder the Pico2 to the PCB. Currently only versions without header are available, but please solder headers to the Pico and sockets on the PCB. Unsoldering the Pico is almost impossible in case of problems. If you want to experiment with your own code I do recommend to solder a header to the debug interface and use a Pico Probe. I use this all the time and it is just one or two mouse clicks in VS Code to compile and run a new version without having to go into BOOTSEL mode. Regards, Meindert |
10-16-2024, 07:53 AM
I received the 2 mine (France), I have to order the components that I do not have in stock (including the Pico2). |
10-16-2024, 10:45 AM
(10-16-2024 07:18 AM)MeindertKuipers Wrote: Good luck building it, and let me know how it goes. Most of the orders are now on their way or have already arrived. For the Pico2, just pick the right webshop, after the initial wait I had no issues getting my hands on multiple units. Sure ! Advice taken. I'll use headers anyway. Thanks. |
10-17-2024, 11:34 PM
I received mine today, thanks Meindert!
10-27-2024, 03:22 PM
Just uploaded all sources again to https://github.com/mjakuipers/TULIP-DevBoard. The new firmware binary is in the TULIP4041-P2 build directory again (the .uf2 file).
Latest changes: - serial port connects and disconnects are reported in the CLI - PILBox connect status changes are reported in the CLI - TRANSMIT ERR still occurs when there is a serial connection but no virtual IL device (PILBOX status is TDIS). This is intentional - The HP-IL scope now shows the tracer sample counter for better correlation. There may be some jitter About the trace counter: this is generated in real time for each HP41 T0-T0 cycle, even when the tracer is not connected, disabled or when samples are filtered. The shown trace samples lag behind the calculator activity. Have fun and let me know your feedback. Regards, Meindert |
10-27-2024, 07:44 PM
(10-27-2024 03:22 PM)MeindertKuipers Wrote: Just uploaded all sources again to https://github.com/mjakuipers/TULIP-DevBoard. The new firmware binary is in the TULIP4041-P2 build directory again (the .uf2 file). "VERSION 00.01.05 BETA - build time: 2024/10/26_15:02:06" Updated on my development board today. All items noted in your post checked out. When connecting pyILPER the following are reported in the CLI: Code:
Cheers, Craig (having fun!) Try CC41! |
10-28-2024, 09:54 AM
(10-27-2024 07:44 PM)Craig Bladow Wrote:It is indeed a bit out of place, I thought about this. But the firmware is too quick and sees a serial port connection and issues the warning before it has seen the PILBox conncting. I might try a timer on the warning, but that is not very straightforward, Regards, Meindert |
10-28-2024, 05:13 PM
(10-28-2024 09:54 AM)MeindertKuipers Wrote:(10-27-2024 07:44 PM)Craig Bladow Wrote:It is indeed a bit out of place, I thought about this. But the firmware is too quick and sees a serial port connection and issues the warning before it has seen the PILBox conncting. I might try a timer on the warning, but that is not very straightforward, I suspected it was related to timing and agree that a delay solution may be more complicated than it is worth. If the software is aware of the state of HP-IL being connected or not connected then emitting a a connection statement when the HP-IL connection state changes may be a way to assure the user that the warning was just temporary. Something like: Code:
Cheers, Craig Try CC41! |
10-28-2024, 06:49 PM
(10-28-2024 05:13 PM)Craig Bladow Wrote: Something like:I will indeed add a message that the HP-IL loop is closed or open with the PILBox status change. Regards, Meindert |
10-29-2024, 06:51 PM
(10-28-2024 05:13 PM)Craig Bladow Wrote: Something like: Maybe interested why the PILBox mode is changed twice, 1st to COFF and then 2nd to COFI. At PILBox Power On reset, the PILBox is in TDIS mode. This means all traffic on the HP-IL side is forwarded through the PILBox. To notify the PILBox that the controller is on HP-IL side and we want to listen the frames on the USB side, we set the PILBox to COFF mode. But why not send COFI directly as initial frame? The COFI mode was introduced in PILBox firmware 1.6, before 1.6 the COFI command was ignored. So, when you have a PILBox with firmware 1.4 and you send the COFI command directly as 1st command, the PILBox will still remain in TDIS mode. But when you first send COFF, every PILBox firmware will switch to the COFF mode. And when you then send COFI, all COFI capable firmware (1.6, 2.0, 2.1) will switch to COFI mode, all others remain in COFF mode. On pyILPER and ILPilbox the COFI mode must be enabled by checkbox: pyILPER "Enable IDY frames" and Ilpilbox "IDY frames". At ILPer the COFI mode is enabled by default. |
