TI-58C Clone
10-29-2024, 04:16 PM
RE: TI-58C Clone
(10-29-2024 12:01 PM)AnnoyedOne Wrote:
(10-28-2024 07:47 PM)Pierre Wrote:  The site only sells in kit form.
Unfortunately that's a deal breaker for me Sad Due to age related issues I can no longer solder things. I did for decades so I know how...
So my search for a decent emulator (not a simulator) continues. And yes Pierre I've tried yours.
A1
You don't know anyone who would assemble it for you? I assemble kits for all my friends just for the pleasure of the assembly. In fact, when I buy a kit, I assemble it, test it then usually give it away or sell it cheaply because that's the fun of it for me.
Tom L
Cui bono?
10-30-2024, 10:50 AM
RE: TI-58C Clone
(10-29-2024 12:01 PM)AnnoyedOne Wrote:  So my search for a decent emulator (not a simulator) continues.
Being attached to semantics, I will therefore repeat here the introductory message present on my site :
Quote:It seems that some people qualify my TI-58C program as a simulator on the pretext that an emulator is a program which takes the kernel (ROM) of a machine "to run" it, in computer science, in France, it is common to say "to process" it.
To be precise with French terms:
the verb "to simulate" designates the action of imitating, pretending. (The flight simulator represents well the action of imitating and feigning. Some women have the art of pretending or feigning : in short simulating.)
the verb "to emulate" refers to the action of trying to match or surpass... which my TI-58C program does!
When the execution of a ROM from a calculator, it would surely be more judicious to speak of "executor", or even of "processor" or ROM "engine".
In any case, I don't believe that my program imitates, pretends or feigns ..."
So, AnnoyedOne, if you are looking for a ROM microcode "executor" I recommend :
The “puristTI59e of Hrast Programmer (https://www.hrastprogrammer.com/ti59e/ and http://www.hrastprogrammer.com/ti59e/ti59epc.zip)
(10-29-2024 12:01 PM)AnnoyedOne Wrote:  And yes Pierre I've tried yours
Thanks for trying, and sorry it didn't meet your expectations.
http://ti58c.phweb.me
http://clones.phweb.me
http://www.instagram.com/ti58c
"No! Do or Do not. There is no try!" [Master Yoda]
10-30-2024, 12:56 PM
RE: TI-58C Clone
(10-30-2024 10:50 AM)Pierre Wrote:  So, AnnoyedOne, if you are looking for a ROM microcode "executor" I recommend :
That my definition of an emulator yes. Runs the original ROM code vs what anyone thinks it does/should do (simulator).
I've tried the Hrast Programmer emulator. No thanks.
A1
PS: It seems that TI has threatened anyone who publicly publishes ROM images of ancient products. Their code and choice. I assume that's why there's are almost no emulators but many simulators.
10-30-2024, 04:28 PM (This post was last modified: 10-30-2024 04:30 PM by Matt Agajanian.)
RE: TI-58C Clone
Hi all.
Some insight, please. The faceplate of the ET-58 in the OP looks a bit crowded and cluttered with way too much nomenclature. Is that the actual faceplate or is that from a prototype?
10-30-2024, 04:50 PM
RE: TI-58C Clone
(10-30-2024 04:28 PM)Matt Agajanian Wrote:  Is that the actual faceplate or is that from a prototype?
That is the actual faceplate !
When, like me, you know the TI-58C keyboard, nothing monstrous.
Just a 3rd function to assimilate in addition.
3 functions per key is quite usual on HP... (without speaking about the WP34S)
To explain :
Above the button in large characters: the basic function
To the left of the button, upper text: the 2nd function
To the left of the button, lower text: the 3rd function
Ex:
the 1/X key gives tan if 2nd before 1/X and gives tanh if 3rd before 1/X...
(We can also make a color overlay)
11-01-2024, 01:13 PM
RE: TI-58C Clone
Among the "plus" I was going to forget :
[Image: alpha.jpg]
the alphanumeric display that the TI-58C did not know!
To which must be added a list of 112 pre-recorded terms to help compose the texts.
(OK, ERROR, Diagnose, Result, Input, Enter, Index, Row, Column, Continue, STOP, Matrix, Complex, Number, Element, Item...)
11-01-2024, 02:33 PM
RE: TI-58C Clone
Very interesting. TI deserves clones as well as HP. Will buy one when available.
@Pierre. tu as mis un drapeau hongrois au lieu d’un drapeau tchèque sur ton site.
My site http://www.emmella.fr
11-01-2024, 03:17 PM
RE: TI-58C Clone
(11-01-2024 02:33 PM)badaze Wrote:  @Pierre. tu as mis un drapeau hongrois au lieu d’un drapeau tchèque sur ton site.
@badaze. Merci mais je ne me suis pas trompé sur mon site mais sur mes deux sites !
11-01-2024, 11:19 PM
RE: TI-58C Clone
(11-01-2024 01:13 PM)Pierre Wrote:  Among the "plus" I was going to forget :
[Image: alpha.jpg]
When you post an image from your site, I think you should remove http:// after [img], because I can’t see it.
I would certainly buy this clone if it was sold assembled...
Jean-Charles
11-02-2024, 12:58 AM
RE: TI-58C Clone
[Image: alpha.jpg]
Same here! (hint for ET-58 maker :)
11-02-2024, 07:41 AM
RE: TI-58C Clone
(11-01-2024 11:19 PM)Helix Wrote:  I think you should remove http:// after [img], because I can’t see it.
Sorry but without http://
[img]clones.phweb.me/download/alpha.jpg[/img]
otherwise with https://
[Image: alpha.jpg]
11-02-2024, 08:17 AM
RE: TI-58C Clone
Hé, les gars, pas besoin de chuchoter. On a du mal à vous entendre sans une loupe ! Big Grin
Current daily drivers: HP-41CL, HP-15C, HP-16C
11-03-2024, 11:47 AM (This post was last modified: 11-03-2024 11:54 AM by Marc van Lemmen.)
RE: TI-58C Clone
Hello Pierre, Thank you for pointing this out ! Nice ! And thanks to Miroslav Nemecek for creating the ET-58.
My first programmable device was a TI-57, I couldn't afford a TI-58 or 59. I had an oppertunitie to play with a TI-58 for a couple of weeks, and I still love it. So when I saw your post, I immediatly ordered a kit ! It arrived yesterday, but now I have to find the time to solder it.
Luckely there are only two smd parts, I'm no hero soldering smd Smile
Marc.
11-03-2024, 12:41 PM
RE: TI-58C Clone
(11-03-2024 11:47 AM)Marc van Lemmen Wrote:  Hello Pierre, Thank you for pointing this out ! Nice ! And thanks to Miroslav Nemecek for creating the ET-58.
Marc.
Hi Marc,
Congratulations on your purchase.
Don't hesitate to take pictures during your assembly work that will be useful to other fans. (and I can publish them on my site with your agreement!)
And your comments will be welcome.
For my part, being bad at electronics and especially at soldering, I can only help you with the use and programming of the ET-58.
For the manual you will have to be patient... I have as much skills in Czech as in soldering... but I will know how to do it!
I have already made a 259 steps program that I immediately transposed for the PX-41CX then for the HP-15C...
Have fun !
Best regards
Pierre
11-03-2024, 06:42 PM (This post was last modified: 11-03-2024 06:43 PM by Marc van Lemmen.)
RE: TI-58C Clone
Have fun !
Best regards
Pierre
Hi Pierre,
I will take pictures when I assemble/solder the ET-58 and post them here, and you may put them on your site. The building instructions, in English, can be found at : https://www.breatharian.eu/hw/et58/index_en.html
I first have to make room in my office or storage. both are packed Smile
Best regards,
Marc.
11-08-2024, 01:47 PM
RE: TI-58C Clone
The Pajenicko.cz website has restocked the ET-58 kits and is therefore putting several of them back on sale!
11-08-2024, 04:44 PM
RE: TI-58C Clone
I’ve just ordered one.
I just have to learn how to solder !
Cost 43€ shipping to France included.
11-08-2024, 06:06 PM
RE: TI-58C Clone
(11-08-2024 04:44 PM)badaze Wrote:  I’ve just ordered one.
Félicitations !
Je pense que vous aurez fini le montage avant que j'ai pu terminer le manuel.
Le manuel en français avance doucement...
J'en suis à une trentaine de pages sur 260 environ...
Plus que 230 pages à faire avant d'attaquer la version anglaise !
Congratulations !
I think you will have finished the soldering before I had finish the manual.
The French owner's manual is progressing slowly...
I am at about thirty pages out of about 260...
Only 230 pages to translate before starting the English version !
11-09-2024, 09:31 PM
RE: TI-58C Clone
Hi Pierre,
I am ready soldering the ET-58, but I have to find out how to program the Atmega328p. I'm only familiar with pic microcontrollers, and Arduino ( also a 328p, but with a bootloader ).
For now I've used an ic socket so I can reprogram the 328p. It only makes the distance from the top cover plate to the pcb greater, I'll have to find out if this is workable once I have a working 328p.
I'll let you know if there's any progress.
Regards, Marc.
11-09-2024, 10:41 PM
RE: TI-58C Clone
(11-09-2024 09:31 PM)Marc van Lemmen Wrote:  Hi Pierre,
Regards, Marc.
Hi Marc,
Thanks for the information.
I will be very interested in your progress.
Best regards
Pierre
