Old programs do not run
11-01-2024, 01:17 PM
After a long time, I wanted to start my few programs again. But none of them can still run. When I look at the program text and select "check", I only get the error message "Error: Syntaxerror". And that with every program. Then when I press ESC twice, I always get the message that there is a syntax error on line 6.
Here is my simplest test program: EXPORT Testinput() BEGIN LOCAL name; INPUT ({{name, [-1]}}, "Name", "Please type in a name"); PRINT("Hello " + name); END; Why am I getting a syntax error with this tiny program now? Thank you for your help! HP-15C, HP-15C LE, HP-15C CE, HP-16C, HP-35S, HP Prime G1, HP Prime G2 |
11-01-2024, 04:17 PM
RE: Old programs do not run
I opened a new program on my emulator, emptied it and copied your text in. Check: No errors, program runs as expected. Software is: 2.1.14730 Arno |
11-01-2024, 06:46 PM
On both Primes the same, both with actual firmware: The program does not run.
11-01-2024, 08:12 PM
do you have the latest firmware 2.2 9/1/24
on my G2 with the latest firmware I copied and pasted the program and it seems to works ok no error |
11-01-2024, 08:30 PM
(This post was last modified: 11-01-2024 08:35 PM by BuSchu.)
(11-01-2024 08:12 PM)Dougggg Wrote: do you have the latest firmware 2.2 9/1/24 As I wrote: actual firmware. And actual means latest, of course. All my old programs report a syntax error in line 6. Could it be a configuration problem? Now I saw: The following short program shows a syntax error in line 1: EXPORT Mopmt (L, R, M) BEGIN LOCAL K := R / 1200; K := L * K / (1 - (1 + K)^ -M); RETURN "Payment = " + K; END; HP-15C, HP-15C LE, HP-15C CE, HP-16C, HP-35S, HP Prime G1, HP Prime G2 |
11-01-2024, 08:57 PM
Now I cleared memory and keyed in the program mompt and it works.
11-01-2024, 08:59 PM
After restoring the backup before the memory reset the error is there again.
11-01-2024, 09:34 PM
Did you consider inserting something like this:
Code: #pragma mode( separator(.,;) integer(h32) ) The #pragma line ensures that your preferred settings are used when compiling the text into a program. More about the #pragma directive can be found here in the hpmuseum forum. -- Ray |
11-01-2024, 10:12 PM
(11-01-2024 09:34 PM)Raymond Del Tondo Wrote: Did you consider inserting something like this: I think, that's it. I configured , as the separator as common in Germany. Thanks! HP-15C, HP-15C LE, HP-15C CE, HP-16C, HP-35S, HP Prime G1, HP Prime G2 |
11-02-2024, 08:25 AM
(11-01-2024 08:30 PM)BuSchu Wrote: As I wrote: actual firmware. To remove some confusion here, I think BuSchu means "up-to-date" firmware, which is "actuel" in French. One of the many false friends between the two languages. Current daily drivers: HP-41CL, HP-15C, HP-16C |
11-02-2024, 09:27 AM
(11-02-2024 08:25 AM)RPNerd Wrote:(11-01-2024 08:30 PM)BuSchu Wrote: As I wrote: actual firmware. Thanks. I didn't know that until now! HP-15C, HP-15C LE, HP-15C CE, HP-16C, HP-35S, HP Prime G1, HP Prime G2 |
