HP Prime Beta Firmware Version 2.2 Revision 15008
09-02-2024, 06:41 PM
(This post was last modified: 09-02-2024 06:43 PM by Insoft.)
Post: #121
RE: HP Prime Beta Firmware Version 2.2 Revision 15008
(09-02-2024 06:31 PM)ftneek Wrote:(09-02-2024 06:25 PM)Insoft Wrote: All I get is "Could not connect to the update server" what's your config.xml file look as this is mine. Code: <config> |
09-02-2024, 06:53 PM
(This post was last modified: 09-02-2024 07:01 PM by ftneek.)
Post: #122
(09-02-2024 06:41 PM)Insoft Wrote: what's your config.xml file look as this is mine. Ah, when I posted the url for the host, it automatically became a hyperlink. I updated that post to remove the hyperlink. The host tag should not contain http:// , so it should be this: Code: <host>www.moravia-parts.com</host> Here's my config file, in case anyone just wants to replace theirs. - neek |
09-02-2024, 07:09 PM
Post: #123
(09-02-2024 06:53 PM)ftneek Wrote:(09-02-2024 06:41 PM)Insoft Wrote: what's your config.xml file look as this is mine. Thanks, I was wondering about that part since it was stated in the <protocal> |
09-02-2024, 08:31 PM
Post: #124
When is it expected to get the official update?
09-02-2024, 08:37 PM
Post: #125
RE: HP Prime Beta Firmware Version 2.2 Revision 15008 | |||
09-02-2024, 10:20 PM
Post: #126
I’m still getting the help for TEXTOUT for TEXTSIZE.
Perhaps the next update can address some of the mistakes in the help section as well as a few typos Not super important but would be nice to see. |
09-02-2024, 10:48 PM
Post: #127
(09-02-2024 10:20 PM)Insoft Wrote: I’m still getting the help for TEXTOUT for TEXTSIZE. The revised documentation has not been included in this firmware release; work on it is still ongoing... Piotr Kowalewski |
09-03-2024, 01:13 AM
Post: #128
(09-02-2024 05:58 PM)ftneek Wrote:https://www.moravia-parts.com/hp-prime/beta.html Wrote:At the moment, there are no public beta downloads. I’ve done exactly that, using TextEdit to edit the XML file. When I check for updates, I get an “Expected character data” error message, referring to the config.xml file. Should I be using something other than TextEdit on it? |
09-03-2024, 01:49 AM
Post: #129
(09-03-2024 01:13 AM)dbrothers Wrote: Should I be using something other than TextEdit on it? I happened to use Xcode to save the updated file. You can also try replacing the config file with the one in this reply. - neek |
09-03-2024, 02:21 AM
Post: #130
(09-03-2024 01:49 AM)ftneek Wrote:(09-03-2024 01:13 AM)dbrothers Wrote: Should I be using something other than TextEdit on it? For whatever reason, your file worked. I have Xcode installed (I’m a Mac/IOS developer), but it wasn’t one of the options under “Open With” when I right-clicked the config file. |
09-03-2024, 04:50 AM
Post: #131
(09-03-2024 02:21 AM)dbrothers Wrote: For whatever reason, your file worked. The issue was probably TextEdit, I think by default it saves files in the Rich Text Format. I ran into a similar issue recently when I was writing a script that expected a txt file, I used TextEdit but didn't change the file format. - neek |
09-04-2024, 06:22 AM
Post: #132
(09-03-2024 01:13 AM)dbrothers Wrote: I’ve done exactly that, using TextEdit to edit the XML file. When I check for updates, I get an “Expected character data” error message, referring to the config.xml file. Should I be using something other than TextEdit on it? textedit worked fine for me. it should save in whatever format the file was originally in. It does RTF only if you are creating a new file. |
09-19-2024, 04:47 PM
Post: #133
Hello
When will the hp-prime app be available for both PC and mobile devices? |
09-19-2024, 07:59 PM
Post: #134
(09-19-2024 04:47 PM)compsystems Wrote: Hello No offense to any poster (including this one), but this plays in my head whenever I see a question like this Remember kids, "In a democracy, you get the government you deserve." |
09-21-2024, 10:42 AM
Post: #135
(09-19-2024 07:59 PM)mfleming Wrote: ...No offense to any poster (including this one), but this plays in my head whenever I see a question like this [/quote] Wrong answer. In the past, it was common practice for HP to deliver the Virtual Calculator with the computer firmware (often at the same time). It would certainly be very welcome if Moravia continued this practice. |
09-21-2024, 01:06 PM
Post: #136
An update of the Android app would also be very welcome. The version on my phone is the beta from May 2021 with version 2.1.14591.
Current daily drivers: HP-41CL, HP-15C, HP-16C |
09-21-2024, 07:19 PM
Post: #137
09-21-2024, 10:07 PM
Post: #138
(09-21-2024 01:06 PM)RPNerd Wrote: An update of the Android app would also be very welcome. The version on my phone is the beta from May 2021 with version 2.1.14591. It's true, the HP Prime Android app is the most outdated version. Even the Virtual Calculator is from 2023, but on Android, it really seems that the development is abandoned. I hope the dear developers update those apps (Virtual Calculator, Connectivity Kit, and Android app). |
12-08-2024, 02:21 AM
(This post was last modified: 12-08-2024 09:00 PM by jte.)
Post: #139
(09-19-2024 04:47 PM)compsystems Wrote: Hello For Windows, version 2.2 of the HP Prime Virtual Calculator is available, but updating is not directly possible in the HP Prime Virtual Calculator program as the domain name for the update server was changed (i.e., where the HP Prime Virtual Calculator goes to look for updates). To update to 2.2,
Code: <config> Using notepad is one way to do this. (The file must remain a plain text file.) What has changed is the text content in the "host" and "folder" elements. (If editing the config.xml file: launch the HP Prime Virtual Calculator program after making the change and then check for updates from within the HP Prime Virtual Calculator.) Similarly with the HP Connectivity Kit. |
12-08-2024, 05:57 PM
Post: #140
Hello
What are the changes in this new version? |
