cross calling ppl and #cas ???
10-04-2015, 12:21 PM
So what are the argument and evaluation rules when
(1) a ppl function calls a #cas func (2) a #cas function calls ppl (3) a ppl fun passes cas variables I get different results and sometimed brutsl crashes depending on the args and functions. I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-05-2015, 07:13 AM
RE: cross calling ppl and #cas ???
Easy answer: I can't even remember! Ok, looking in the code, here are the rules: From PPL to CAS - Parameters are NOT evaluated prior to the CAS call Unless it is a list - All local variables in the parameters are replaced by their values (because CAS does not have access to local variables) - Parameters which are Strings are parsed by the CAS parser - CAS default variable is changed to X, Y and theta depending on the current app - CAS function is evaluated - CAS default variable is restored - CAS Result is transformed into PPL construct and returned from CAS to PPL - All arguments are evaluated - Arguments are transformed into PPL constructs and PPL function is called - Result is transformed back into CAS and returned Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
10-05-2015, 03:27 PM
I presume you mean the CAS (....) call.
How about calling a #cas function.. from ppl? e.g. #cas f (a,b):=......#end then in ppl call f a:= f (n,m); Anything different here? I work with android Prime only for now on my Galaxy Tab Pro/Note 2 |
10-05-2015, 03:36 PM
(10-05-2015 03:27 PM)ji3m Wrote: I presume you mean the CAS (....) call. He means all instances of calling a program or command name that is associated with the CAS side of things. So whether it is a function you created using #cas or a built-in CAS command, what Cyrille posted is an explanation of how inputs are parsed when calling a CAS command/program from within a PPL program or calling a PPL program from within a CAS program. The CAS() command is a PPL command as is the CAS.command() construct. Graph 3D | QPI | SolveSys |
