input does not work anymore (10637 )
09-25-2016, 08:30 PM
I spent lot of time to discover that input cannot be used anymore to handle math expression. Many of my progs does not work anymore here is a simple example I made to show you... In old 8151 firmware this prog did work : Code: EXPORT abc() But in new firmware 10637 it does not work ! => Error. Bad Argument Value surprised this wasn't checked on new firmware release... The problem is that int() does not accept string anymore, is that a bug ? But I found that I still could use single quote like this : int('2*X') But what the hell ?! how can I get single quote out of a PRINT() ? Documentation does not explain it... And WHERE is this f*** list of allowed types ?!!! And is there an "algebraic" type ? I spent hours on that. It is still possible to make program that manipulate math algebraic expression from user input ??? |
09-25-2016, 11:43 PM
RE: input does not work anymore (10637 )
Try:
Code: EXPORT abc() -road |
09-25-2016, 11:51 PM
And see the document by Cyrille de Brébisson in post #9 of this thread for a more complete explanation:
http://www.hpmuseum.org/forum/thread-621...light=kids -road |
09-25-2016, 11:56 PM
I meant to type:
print(int(eval(a))); in the modification of your code but you should get the idea. -road |
