This is a code viewer for HP-Prime
10-08-2016, 05:32 PM
Notice: It seems that the code viewer is only fit for the r10077 or above. But you can have a try using r8151.
Attached File(s)
.zip  codeviewer.zip (Size: 4.52 KB / Downloads: 60)
10-09-2016, 05:00 AM
RE: This is a code viewer for HP-Prime
(10-09-2016 03:04 AM)compsystems Wrote:  excellent highlighting code.
I would like an option to automatically tabulate a code (format)
Try this converter - it will tabulate your codeSmile
07-18-2018, 08:23 AM
I know this app is here for some time but is it compatible with the last FW 2018 ?
On my machine, it starts and asks for a prog to open then nothing happen.
Could you please confirm?
07-20-2018, 02:57 AM
(07-18-2018 08:23 AM)scorpio72 Wrote:  I know this app is here for some time but is it compatible with the last FW 2018 ?
Yes it is, however the author is trying to allocate a gigantic screen image for display which is why it doesn't run on your hardware. The memory limits are being exceeded.
Take a look at the line DIMGROP_P(G1,768,14*rowm+5)
That is trying to allocate an image that is 768 pixels wide, by 14*512*+5 high *32 bits per pixel .... ~22MB. Previously at 16bits per pixel it is possible it might have worked on a rather empty unit.
So that is why the program is not working. In order to work properly on hardware, a routine that either handles a smaller portion of the code at one time, or some other more intelligent methods will be needed.
TW
