Bug in Complex_vector .^ (-1) [SOLVED]
04-30-2017, 09:54 AM (This post was last modified: 02-02-2018 08:47 PM by JMB.)
The following command gives a wrong output in HOME (FW 10637, VC 11226):
[i, -i] .^ (-1) → [1-i, 1+i]
In CAS you get the correct answer:
[i, -i] .^ (-1) → [-i, i]
If you use lists instead of vectors, you get the correct result both in HOME and CAS:
{i, -i} .^ (-1) → {-i, i}
05-01-2017, 05:21 AM
RE: Bug in Complex_vector .^ (-1)
Thanks, we will look at it.
Cyrille
05-01-2017, 05:31 PM
Thank you for your time, Cyrille!
02-02-2018, 08:48 PM
RE: Bug in Complex_vector .^ (-1) [SOLVED]
Corrected in firmware 13333.
Thanks to the HP Prime Team!
