menu programming
09-03-2017, 05:25 AM
(This post was last modified: 09-03-2017 05:30 AM by webmasterpdx.)
menu programming
The prime really doesn't have much to help you program menus.....which I hope they'll fix in a future release. I found a few useful titbits to help get around that shortfall.
Here are 2 very useful utilities to put in your programming utilities. PUTMENU and GETMENU. See here... https://www.thecalculatorstore.com/Calcu...e-HP-Prime I'll try to post an example using them when I get a chance... -Donald |
09-03-2017, 06:46 AM
(This post was last modified: 09-03-2017 06:50 AM by webmasterpdx.)
RE: menu programming
Here is a simple example that I just wrote and works fine....a lot simpler than programming from scratch. This example puts a few menu selections. I've only implemented the EXIT selection.
09-03-2017, 05:46 PM
You can also use libMenu, something I made and share here : http://www.hpmuseum.org/forum/thread-7220.html video demonstration posted on thread. it does not work exactly the same as you, you have to define a function for each of your menu entries. these functions will be called-back on user action. it's quite easy to use, and you also have more enhanced versions that can handle enhanced features (toggle menu...) primer |
09-03-2017, 07:44 PM
LibMenu looks nice. I like mine though for simple apps....as it's so simple, and I retain control over everything.....my "lib" is just 2 functions. I should post them here as the link I gave isn't exactly what I'm using....I changed the GETMENU function slightly.
09-04-2017, 11:08 AM
I found that it executes better if the WAIT call is used instead of MOUSE as in this example...
