Challenge: Generate a 64 in the display (RPN)
09-02-2020, 08:56 PM
Your challenge is to take a classic RPN machine in an unknown stack circumstance and generate a 64 in the X register.
You may not use any of the digit keys 0 - 9, the EEX key or the decimal point. Who can come up with the shortest set of steps ? |
09-02-2020, 09:39 PM
(This post was last modified: 09-02-2020 09:43 PM by BruceH.)
RE: Challenge: Generate a 64 in the display (RPN)
9 steps on an 11C - the most obvious method so I expect to be beaten!
09-02-2020, 10:11 PM
5 steps, HP-41C.
09-02-2020, 10:38 PM
9 steps HP 42s ... how to get to five.....
Try CC41! |
09-02-2020, 10:49 PM
According to https://hpmuseum.org/ none of the entries so far are from "The Classics".
On an HP 41-cx I can do this in 4 program steps. Try CC41! |
09-02-2020, 10:52 PM
7 steps in the HP-25, no modes or contents assumed. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
09-02-2020, 10:56 PM
(This post was last modified: 09-02-2020 11:04 PM by Guenter Schink.)
25C 8 steps
41c 5 steps Günter |
(09-02-2020 10:49 PM)Craig Bladow Wrote: According to https://hpmuseum.org/ none of the entries so far are from "The Classics". Yes, the “Classics” encompass only the HP-35, HP-80, HP-45, HP-65, HP-70 and HP-55. Perhaps I can use part of my sequence on the HP-65, but then again I assume Gene’s solution should work on all Classics. |
09-02-2020, 11:09 PM
(09-02-2020 10:56 PM)Gerson W. Barbosa Wrote: Yes, the “Classics” encompass only the HP-35, HP-80, HP-45, HP-65, HP-70 and HP-55. Are you implying that the HP-25 isn't a classic !!?? C'mon, Gerson ! V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
09-02-2020, 11:24 PM
(09-02-2020 11:09 PM)Valentin Albillo Wrote:(09-02-2020 10:56 PM)Gerson W. Barbosa Wrote: Yes, the “Classics” encompass only the HP-35, HP-80, HP-45, HP-65, HP-70 and HP-55. I consider even the more recent HP-15C, my first one, a Classic. The above is the curator’s definition. Best regards, Gerson. |
09-02-2020, 11:44 PM
(09-02-2020 11:24 PM)Gerson W. Barbosa Wrote:(09-02-2020 11:09 PM)Valentin Albillo Wrote: Are you implying that the HP-25 isn't a classic !!?? C'mon, Gerson ! Yes, but we aren't dealing here with "the curator's definition". Notice that Gene's OP literally says (my underline): "Your challenge is to take a classic RPN machine [...]" with no quotes around "classic", no capitalization "Classic", no underline of course, and no reference to the curator's "The Classics (1972)". Best regards. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
09-03-2020, 01:32 AM
By "classics" I merely meant to exclude the WP-34S, the 71B, the RPL machines etc.
Gene |
09-03-2020, 01:36 AM
HP-65 10 steps
Try CC41! |
09-03-2020, 04:43 AM
(This post was last modified: 09-03-2020 04:51 AM by Mark Hardman.)
HP42s - 5 steps
Edit: 4 steps Edit 2: 3 steps Ceci n'est pas une signature. |
09-03-2020, 05:23 AM
(09-03-2020 04:43 AM)Mark Hardman Wrote: HP42s - 5 steps In the HP42s and some models of the 41 it can be done in 2 steps. V. All My Articles & other Materials here: Valentin Albillo's HP Collection |
09-03-2020, 05:41 AM
42S: 2 steps
Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
09-03-2020, 06:10 AM
Gene: 'generate a 64 in the X-register'
.. that is not quite the same as saying 'generate the number 64 in the X-reg', is it? in that case: 41C: 3 steps Werner 41CV†,42S,48GX,49G,DM42,DM41X,17BII,15CE,DM15L,12C,16CE |
09-03-2020, 08:39 AM
Yes, 2 steps and 4 bytes on the HP-42S. Only because now I know it is possible.
09-03-2020, 09:10 AM
(This post was last modified: 09-03-2020 09:11 AM by Thomas Okken.)
How about the smallest number of keystrokes?
I thought that was what Gene meant, actually, and the minimum number of program steps does seem to be a bit too easy. On the 42S anyway. |
09-03-2020, 09:14 AM
(This post was last modified: 09-03-2020 09:15 AM by Sylvain Cote.)
RE: Challenge: Generate a 64 in the display (RPN) | |||
User(s) browsing this thread:
