Firmware 2021: Problem with exact polar form
04-27-2021, 09:01 PM (This post was last modified: 04-28-2021 01:41 AM by compsystems.)
Hello
Flags: HOME view & RAD MODE (HAngle:=0) & (HComplex:=01).
HAngle:=0; HComplex:=01; [ENTER]
Example 1: ok
input: approx polar form
rectangular_coordinates( 4 ∡ 0.523598775598 ) [ENTER] [ 3.46410161514, 2 ] // OK. a+b*i > 3.46410161514 + 2*i
input: exact polar form
rectangular_coordinates( (4 ∡ (π/6)) ) [ENTER] [ 3.46410161514, 2 ] // OK
input: exact list form
rectangular_coordinates( [ 4, π/6 ] ) [ENTER] [ 3.46410161514, 2 ] // OK
input: approx list form
rectangular_coordinates( [ 4, 0.523598775598 ] ) [ENTER] [ 3.46410161514, 2 ] // OK
polar_coordinates( [ 3.46410161514, 2 ] ) [ENTER] [ 4, 0.523598775598 ] // OK
example 2: Problem
rectangular_coordinates( (√(2) ∡ (3*(π/4))) ) [ENTER] Error: Syntax Error Why?
rectangular_coordinates( 1.41421356237 ∡ 2.35619449019 ) [ENTER] [ −0.999999999995, 1 ] // OK
a+b*i > −0.999999999995 + i
rectangular_coordinates( [ √(2) , (3*(π/4)) ] ) [ENTER] [ −0.999999999995, 1 ] // OK
rectangular_coordinates( [ 1.41421356237, 2.35619449019 ] ) [ENTER] [ −0.999999999995, 1 ] // OK
polar_coordinates( [ −0.999999999995, 1 ] ) [ENTER] [1.41421356237,2.35619449019] // OK
04-28-2021, 09:22 AM
RE: Firmware 2021: Problem with exact polar form
Honestly, I am not 100% sure of the why. This is code I created so long ago...
With a cursory look, it seems that the problem comes from the fact that my parser is not able to recognize "expression"angle"expression" as a complex number.
only number angle "expression" will work.
Unfortunately, this is not an easy fix. sorry
Cyrille
04-30-2021, 04:43 AM (This post was last modified: 04-30-2021 04:47 AM by compsystems.)
In Home mode, I found the solution: you must put a comma before the Unicode angle symbol
(√ (2), ∡ (3 * (π / 4)))
For those of us who work in the field of teaching circuits in electrical and electronic engineering, we use the option of complex numbers in polar form a lot, is also difficult to remember to place the comma before the angle symbol, for this reason it is very useful to have a template for this purpose. Who else has to enter complex numbers in polar format?
Another useful template is CEILING ⌈▣⌉ AND FLOOR ⌊▣⌋, widely used in algorithmic
[Image: math_templates_hpprime.png]
