New Version 2016 10 17. Rev:10638
10-24-2016, 04:55 PM
RE: New Version 2016 10 17. Rev:10638
(10-24-2016 03:19 PM)Tim Wessman Wrote:(10-24-2016 02:18 PM)toml_12953 Wrote: The virtual calculator has an updated version. I'd like the virtual and physical calculators to match even if the differences are minor. Тьфу! Tom L Tom L Cui bono? |
10-24-2016, 06:01 PM
Thanks Tim, Cyrille and the team. New version works perfectly now.
Kind regards John |
10-24-2016, 06:07 PM
Looks like the updated virtual calculator came with an updated User Guide. Not sure what is different. I did notice that invztrans() is still not documented in the User Guide (yes I know it's in the virtual calculator help file for more than a year). Not sure what's updated in the User Guide...
10-24-2016, 08:37 PM
(10-24-2016 03:19 PM)Tim Wessman Wrote: Also, in the future the hardware calculator will most likely be trailing the software only versions. It will be very likely the apps will receive more regular updates for example due to the ease at updating them, and the hardware less frequently. I wouldn't be surprised to see that being the new norm. I'm not sure I understand. Why is it easier (for HP) to update the apps than to update the firmware files for the hardware calculator? Nigel (UK) |
10-24-2016, 09:10 PM
(10-24-2016 08:37 PM)Nigel (UK) Wrote:(10-24-2016 03:19 PM)Tim Wessman Wrote: Also, in the future the hardware calculator will most likely be trailing the software only versions. It will be very likely the apps will receive more regular updates for example due to the ease at updating them, and the hardware less frequently. I wouldn't be surprised to see that being the new norm. Tim makes reference to the virtual calculator apps, not the "prime apps". It is easier of course because no hardware stuff... My website: erwin.ried.cl |
10-25-2016, 12:40 AM
(This post was last modified: 10-25-2016 12:42 AM by Mark Hardman.)
(10-24-2016 03:19 PM)Tim Wessman Wrote: Also, in the future the hardware calculator will most likely be trailing the software only versions. It will be very likely the apps will receive more regular updates for example due to the ease at updating them, and the hardware less frequently. I wouldn't be surprised to see that being the new norm. In a future release of the iOS/Andriod apps, please consider those of us that are left handed and give us an option, when in landscape mode, to swap the keyboard so that it is on the left. If I were a certain, very demanding poster, this is where I would insert a huge image of what was envisioned. In my case, I'm sure you don't need the visual aide. ;-) Thanks, Mark Hardman (Southpaw) Ceci n'est pas une signature. |
10-25-2016, 05:33 AM
Bonjour
Alors que les deux dernières versions de la calculatrice virtuelle refusaient de s'installer sur mon Pc Windows Vista, celle-ci n'a posé aucun problème. Merci. Hello While the last two versions of the virtual calculator refused to install on my Windows Vista PC, it no problem. Thank you Sorry for my english |
10-25-2016, 07:06 AM
(10-24-2016 09:10 PM)eried Wrote:(10-24-2016 08:37 PM)Nigel (UK) Wrote: I'm not sure I understand. Why is it easier (for HP) to update the apps than to update the firmware files for the hardware calculator? It's easier for me to update an Android app on my phone than to download a new firmware file and update my calculator, but I don't see why it should be easier from HPs end. Given the wide range of hardware runnng different Android versions that exists today I would have expected that providing new firmware for the calculator would be more straightforward than making significant changes to the Android app, rather than the other way around. Nigel (UK) |
10-25-2016, 05:30 PM
(10-25-2016 12:46 PM)moonbeam Wrote: Ease might include the support load, when updates go wrong. Yes, that makes sense. I expect that schools use the hardware calculator and so less frequent updates are good for them. Perhaps the mobile apps will provide an opportunity for more beta testing before a firmware update? Nigel (UK) |
10-29-2016, 11:05 PM
Today I finally installed it on my brand new Surface Book and both run without any problems.
Arno |
10-29-2016, 11:45 PM
On Surface if you choose a larger font size, the VC display will not show the bottom row of keys. It seem that picking a larger font size like 250, also enlarges the calculator size.
BM |
10-30-2016, 01:24 AM
(10-29-2016 11:45 PM)BERNARD MICHAUD Wrote: On Surface if you choose a larger font size, the VC display will not show the bottom row of keys. It seem that picking a larger font size like 250, also enlarges the calculator size. Try with And also using the "Large skin" otherwise it is too tiny (but much sharper!) My website: erwin.ried.cl |
10-30-2016, 03:00 AM
I should have been more explicit. I wanted to refer to Surface Pro 4, windows 10'
It seems the Properties does not include the category "Compatibility". I tried 'right click' the 'file folder HP Prime VC in the Program File (x86) folder, then Properties and the categories are General Sharing Security Previous Versions Customize. There is no category for 'Compatibility, unless I'm looking in the wrong place. Thanks BM |
10-30-2016, 04:37 AM
(10-30-2016 03:00 AM)BERNARD MICHAUD Wrote: I should have been more explicit. I wanted to refer to Surface Pro 4, windows 10' Compatibility tab is in the shortcut My website: erwin.ried.cl |
10-30-2016, 09:23 AM
After many, many try it is impossible to install 10638 virtual hpprime on my Windows 10. But the 10638 Conkit was installed automaticaly without problem ! May be people can explain me how to do ? Then I have CK 10638 and Virtual prime 10637. Gérard. |
10-30-2016, 01:20 PM
re; Surface Pro 4 Windows 10 VC Compatibility.
That worked just fine. But who would have thought of looking in the short cut? I was also successful in downloading and installing the CK and VC from the links provided by eried in Post 17 on page 1. I did not have to uninstall CK & VC first. Thanks again eried |
