WTB: Battery contacts HP82240 printer
07-25-2018, 06:17 PM
I am looking for the battery contacts used in the HP 82240A/B printers. Leaking batteries corroded some of these contacts in my printer. Thanks in advance, Kees |
07-26-2018, 10:32 PM
RE: WTB: Battery contacts HP82240 printer
Kees,
I had this problem with my HP-97. It has the same size printer bay as the HP-41 printer and takes the same battery pack as the printer. Now being the World's worst soldering person, I asked a friend to look at it. He came up with the solution of cutting a replacement from an ordinary tin can - this had the required "springy" function but not the best at staying soldered. Then he found one of those big square batteries which some of us of a certain age will remember being used to drive Xmas tree lights. This battery(I think made by EverReady) ) was totally dead but still had the spring copper terminals. He took one of these, bent it to shape and hey presto! You can buy tinned copper lengths on the Web but some have a minimum order of 1 tonne! Dennis Denny Tuckerman |
07-28-2018, 04:35 PM
(07-26-2018 10:32 PM)Leviset Wrote: Kees, Hi Dennis, Thanks for your reply. I am looking for the original battery contacts. Your proposal is plan b. In the past I rebuild contacts by reshaping contacts from other battery holders, but the result was never great. Luckily the battery contacts are never visible from the outside, when the battery holder is closed. ;-) Regards, Kees |
07-30-2018, 11:06 AM
Hi Kees,
the battery contact for the 82240A are the same of HP97 and other HP handheld calculators. I've a good pair of contact from a spare calculator, send me a PM, please. Regards Ignazio Ignazio ______________________________________ RPN...What else! |
07-30-2018, 05:23 PM
(07-30-2018 11:06 AM)ignazio Wrote: Hi Kees, Hi Ignazio, Thanks for your reply, but the HP 82240A/B is supplied by 4 standard AA batteries. (Not the rechargeable battery pack HP 82033A, used by the HP 97 and the HP 82143A printer.) Regards, Kees |
07-30-2018, 08:40 PM
Hi Kees,
Sorry, my mistake. I've make a big mess between 82240A/B and the 82143A printer. Thanks for your reply. Regards Ignazio ______________________________________ RPN...What else! |
