HHC 2019 WP43C addendum
09-29-2019, 07:33 PM
Although this would usually go to "Not quite HP Calculators...." I post this addendum here because it fits the overall discussion of HHC 2019.
I got some feedback on forum.swissmicros.com wrt my talk about the WP43C. The most important was from Jaco highlighting the issue of overlay/faceplate that might be of interest. here is his comment Quote:From Jaco Mostert: The two different labels mentioned above can be seen here. Then you see that the final (tentative) label for the WP43C (not be mixed with the WP43S) differs from that I presented at the HHC. Layout 1A on the left, Layout L2 on the right. Layout L2 as I showed at the HHC (with blue functions/menus) can be seen here. Hope that helps, Günter ...and doesn't add to the confusion |
