Code section TAB test
12-30-2019, 09:28 AM
(This post was last modified: 12-30-2019 09:29 AM by ijabbott.)
All intra-line whitespace below the ruler line consists of ASCII TAB characters. Will the tab stops line up?
Code: 1 2 3 4 5 Nope. — Ian Abbott |
12-30-2019, 01:14 PM
(This post was last modified: 12-30-2019 01:16 PM by Joe Horn.)
RE: Code section TAB test
Never use tabs for anything on the web. Use explicit spaces instead, like this:
Code: 1 2 3 4 5 This actually is a Good Thing, since tab width is variable and therefore unpredictable in plain-text files, whereas spaces are predictable in code blocks in this forum. <0|ɸ|0> -Joe- |
12-30-2019, 06:28 PM
(12-30-2019 01:14 PM)Joe Horn Wrote: Never use tabs for anything on the web. Use explicit spaces instead, like this: Hi Joe, I'm aware of that. The issue of tab stops not lining up came up in a recent thread, so I just created this thread to demonstrate the current behaviour. In theory, it is fixable in the MyBB PHP code (and it would be great if it that also had an option to set the tab width, using something like [code tabwidth=8], for example), although I'm not expecting it to get fixed. The PHP code would just need to work out how many entities to emit for each TAB character, instead of always emitting exactly four entities. — Ian Abbott |
