Does G2 Break this program?
01-18-2020, 04:37 PM (This post was last modified: 01-18-2020 04:38 PM by toml_12953.)
Here's a projectile program that works on my HW A and C machines but doesn't work on my HW D (G2) machine. It passes the syntax check on all three. Can anyone tell me why G2 seems to break it? Try running it with velocity 230 and angle 30. On the older machines, the entire trajectory is plotted. On the G2, only one point is plotted.
FNA(X,Y,Z)
  RETURN X*SIN(Y*0.01745329)*Z-16*Z^2;
TAB(X)
  LOCAL I,T;
  T:="";
  FOR I:=1 TO X DO
    T=T+" ";
  RETURN T;
EXPORT PROJECTILE()
  LOCAL X,K,F2,W4,K1,ANS,TMP,M1;
  HFormat:=1; HDigits:=4;
  X:=MAKELIST(0,C,0,126);K:=MAKELIST(0,C,0,2);
  PRINT();
  //REPEAT
    F2:=0;
    INPUT({M,A},"MUZZLE VELOCITY AND ANGLE",{"FT/SEC: ","DEGREES: "});
    X(0):=0;
    FOR T:=0.2 TO 25 STEP 0.2 DO
      L:=IP(5*T+0.001);
      X(L):=FNA(M,A,T);
      IF X(L)<0 THEN
        BREAK;
      IF X(L)-X(L-1)<=0 AND F2=0 THEN
        IF X(L-1)-X(L-2)<X(L)-X(L-1) THEN
          K(1):=X(L-2);
          W4:=T-0.4+J;
        ELSE
          K(1):=X(L-1);
          W4:=T-0.2+J;
        F2:=1;
        FOR J:=0.01 TO 0.2 STEP 0.01 DO
          K(2):=FNA(M,A,W4);
          IF K(1)-K(2)<=0 THEN
            BREAK;
          K(1):=K(2);
        K1:=MAX(K(1),K(2));
    W:=L-1;
      K(1):=FNA(M,A,T-0.2+J);
      IF K(1)<0 THEN
        BREAK;
    PRINT("MAXIMUM HEIGHT IS "+K1+" FEET");
    Y:=M*COS(A*0.01745329)*(T-0.2+J-0.01);
    PRINT("RANGE IS "+Y+" FEET");
    PRINT("TOTAL TIME AIRBORNE IS "+(T+J-0.01)+" SECONDS");
    IF K1+14>60 THEN
      M1:=1/(IP(K1/60+1));
      PRINT("SCALE OF HEIGHT IS 1 SPACE = "+1/M1+" FEET");
    ELSE
      M1:=1;
    TMP:=TAB(14);
    FOR D:=1 TO 30 DO
      TMP:=TMP+"+";
    PRINT(TMP);
    PRINT("0"+TAB(14)+"+");
    FOR N:=1 TO W DO
      PRINT(0.2*N*M*COS(A*0.01745329)+" +"+TAB(X(N)*M1)+"*");
    //INPUT({{ANS,[2]}},"ANYMORE (YES OR NO)?");
  //UNTIL UPPER(ANS) == "NO";
  HFormat:=0;
Tom L
Cui bono?
01-20-2020, 01:35 AM (This post was last modified: 01-20-2020 01:36 AM by Tim Wessman.)
RE: Does G2 Break this program?
On my mac emulator I just tried it and it worked, then I put it into degrees mode and it printed one item...
First thing I normally check when anything trig related is misbehaving. That it?
TW
01-20-2020, 02:17 AM
(01-20-2020 01:35 AM)Tim Wessman Wrote:  On my mac emulator I just tried it and it worked, then I put it into degrees mode and it printed one item...
Auuuggggh! You are quite correct. The angle mode was degrees on the G2 machine and radians on the others. Thanks for correcting me so gently! Big Grin
Tom L
Cui bono?
