Program using directly the stack
05-02-2020, 07:22 AM
I just received my HP Prime and I try to do a very simple program using the result of a calculation, displayed on the first line of the stack.
How to do it?
My Example:
After a few manipulations, I have the result 125.
I would like to apply the command "R->B" to easily convert and display this value in hexadecimal.
This to avoid to tip: ALPHA R SHIFT 9 -> ALPHA B ENTER
Thanks to help me.
05-02-2020, 11:21 PM
RE: Program using directly the stack
(05-02-2020 07:22 AM)SimonP Wrote:  I would like to apply the command "R->B" to easily convert and display this value in hexadecimal.
First time only: [Toolbox] (Catalog) [9] [up-cursor] [Enter]
Afterwards: [Toolbox] [Enter]
Alternative: Assign R→B to a USER mode key.
<0|ɸ|0>
-Joe-
05-03-2020, 03:30 PM (This post was last modified: 05-03-2020 04:56 PM by pinkman.)
Another alternative :
Put this in a program:
KEY K_Log() // or any key you don’t often use
 RETURN STRING(R→B(Ans));
Then, turning user mode always on (Shift-Help-Shift-Help) will let you convert the Ans value at any time.
Notice that your question is a bit RPL-oriented. We’re all here fans of RPL, but using the Prime will force you to change of paradigm.
