Version 6030 and SVD
06-05-2014, 12:49 AM
Is singular value decomposition (SVD) broken in version 6030?
I just tried a 3x4 and a 2x3 matix (and their transposes) and the Prime freezes up - - after a while, it will reboot. Aargh! Try it in Home or CAS. I believe this worked just fine in the previous firmware. |
06-05-2014, 04:20 AM
RE: Version 6030 and SVD
(06-05-2014 12:49 AM)Helge Gabert Wrote: Is singular value decomposition (SVD) broken in version 6030? Yup, just did a 3x4 in the Home screen and had to put the pin in it after a couple of minutes. HP Prime - sexy hardware ... just don't try and confuse it with complicated stuff like mathematics. |
06-05-2014, 07:41 AM
(This post was last modified: 06-05-2014 07:43 AM by parisse.)
Ok, I've fixed it. Could not see it on giac because lapack is used there.
With the current firmware, SVD will not work for matrices that have more columns than rows, because it does not call correctly qr for completing the basis of q. norlesh, I'm not convinced you really understand what happens here. |
06-05-2014, 10:13 AM
RE: Version 6030 and SVD | |||
06-05-2014, 04:33 PM
(06-05-2014 07:41 AM)parisse Wrote: Ok, I've fixed it. Could not see it on giac because lapack is used there. Thanks for fixing! Hopefully, with the next firmware update (should there be one), also nxm matrices with m>n can be handled. But all of this was correct in ver 5447, or not? |
06-05-2014, 06:16 PM
Maybe, I don't remember, in that case it was perhaps a side effect of improving some commands to handle complex matrices.
