(25) Frequency Synthesis IC
08-23-2020, 01:05 PM
An extract from 1980 Plessey Frequency Synthesis IC Handbook, Plessey Semiconductors, SEPTEMBER 1980 {pgs. 61-64}
" 1. Product Information … Using a calculator to find the division numbers of the NJ8811 and NJ8812 Programming the NJ8811 The NJ8811 requires a sixteen bit binary address to program the division number … … If a Hewlett Packard 25 or equivalent calculator is available the following program (Table 2) may be used to obtain the decimal equivalent directly from the frequency and channel spacing … pg. 62 … Programming the NJ8812 The NJ8812 requires a fourteen bit binary address to program the division number … … If a Hewlett Packard 25 or equivalent calculator is available the following program may be used to obtain the Decimal equivalent directly from the frequency and channel spacing … pgs. 63-64 … " BEST! SlideRule |
