HP50G - Help using OPENFIRE (GREYSCALE) with SYSRPL
10-30-2020, 06:29 PM
I would like some help using OPENFIRE with just SYSRPL commands assuming this is possible
Based on the instructions I have tried this #20 #20 MAKEGROB INVGROB #3 ROMPTR 6CA 002 ( ->4GRAY ) but just get a grob on the stack with vertical lines |
03-29-2021, 02:34 AM
RE: HP50G - Help using OPENFIRE (GREYSCALE) with SYSRPL
(10-30-2020 06:29 PM)JeffB Wrote: I would like some help using OPENFIRE with just SYSRPL commands assuming this is possibleTry execute OFVIEW4 to that grob with vertical lines. Then you can see 20×20 square. S.Korean / HP-50G | fx-570EX | fx-570CW | HP-200LX |
03-29-2021, 07:36 AM
Thanks BINUBALL for your reply
Been a while since I posted this and forgot abut it Will try this out Regards Jeff |
