HP49-50G : Black rectangle variable
03-12-2021, 11:43 PM
Suppose that I am on variables menu.
Suppose that I want that only 5 variables appear by page.
- On 1st page of that menu, for instance:
A1, BLACK_RECTANGLE, A3, A4, A5, A6.
- on 2nd page:
B1, B2, B3, B4, B5 BLACK_RECTANGLE.
My "solution" is to have
instead of BLACK_RECTANGLE
"" '¶¶' STO
"" '¶¶¶' STO
Then {A1, ¶¶, A3, A4, A5, A6, B1, B2, B3, B4, ¶¶¶} ORDER.
Is there a better solution to have real, black rectangle instead of my special characters?
Thanks in advance for your help.
Gil Campart
03-13-2021, 12:39 PM
RE: HP49-50G : Black rectangle variable
You can use the Filer to rename a variable to blanks like ' ' which will show up in the VAR menu as a black rectangle.
Have you considered making a custom menu instead? You could store
{A1, {}, A3, A4, A5, A6, B1, B2, B3, B4, {} }
in CST and the custom menu would display blanks in place of the {} entries.
03-28-2021, 02:07 AM
Thanks for the tips.
For the 1st suggestion : it will not show a full, black rectangle, as the ' sign will appear at the left of the black rectangle, showing in fact its name (' ').
Regards, Gil
03-28-2021, 12:11 PM
Sorry, I tried once again and your solution worked.
Thanks for your insight.
Gil
