Polar and Cartesian on the Same Graph? HP Prime
05-01-2021, 03:40 AM
Hi, is there a way to graph polar and cartesian on the same graph on the HP Prime? In other words, can I graph r(theta) = r*sin(theta) and x^2+y^2=1 on the same plot?
Thanks.
05-01-2021, 05:31 AM (This post was last modified: 05-01-2021 07:36 AM by StephanP.)
RE: Polar and Cartesian on the Same Graph? HP Prime
I'd say: go parametric
convert your fourmula/equation
05-01-2021, 07:19 AM
A less mathematical alternative could put the two graphs on the same screen rather than on the same graph.
I was thinking:
Draw a graph
Save a bitmap
Draw 2nd graph
Load image of 1st graph with some transparency.
Which has the advantage that you don't need to rewrite every equation you may want to share a graph with.
But it's not exactly on the same graph.
Stephen Lewkowicz (G1CMZ)
05-01-2021, 12:31 PM
Thanks guys, I'll keep that in mind. These ways are a good work around to check if my Cartesian to Polar conversions are correct.
05-01-2021, 02:45 PM
Doesn't the Geometry app have this functionality? I've haven't used it much but I know there's the option for all the different types of graphing.
Cemetech | YouTube
05-01-2021, 10:47 PM
Ah yes the Geometry app! This is what I was looking for! You can use plotpolar() and plotimplicit() to graph your polar and cartesian functions respectively. Thank you TheLastMilennial! I watched your in-depth review on the Prime G2 not to long ago and it was great!
