Unable to store a library in port 2 (HP-50g)
09-07-2021, 09:41 PM
(This post was last modified: 09-07-2021 09:43 PM by cahlucas.)
Today I wanted to save a library in port 2 of my HP-50g. That didn't work, instead, I got the following error: "Ins. Mem: 4426, Bytes". Error number #7000h. Then I gave the following command: 2 PVARS, resulting in 466960. So in port 2 I still have 466960 bytes free. The library itself is only 23873.5 bytes in size. This library has already been stored in port 2 several times, without the mentioned error message. What I find strange is the error number. This one should have been: #1Ah, instead, it is #7000h. I don't think the hexadecimal number after the message belongs to this error either. In port 2, I have already stored several other libraries, and the library in question is not one of them. Does anyone know what this error message means and how I can solve this problem? Sincerely, Karel.
I use HP-16C, WP-34S emulator, HP-35s, HP-48GX, HP-50g, and HP Prime G2. |
09-07-2021, 11:45 PM
(This post was last modified: 09-07-2021 11:45 PM by BINUBALL.)
RE: Unable to store a library in port 2 (HP-50g)
Probably this thread can help you. I've got the same error like "Ins. Mem: XXXX, Bytes" while installing extable library. It reminds me.
S.Korean / HP-50G | fx-570EX | fx-570CW | HP-200LX |
09-10-2021, 08:58 AM
Hi guys,
**Be careful using Flashtools with Emu48** I had Flashtools already installed and I was running out memory. Using FTOOL I found left over part of files deleted some time ago. I try to repack port 2 and that's when everything went very bad, catastrophic. Every time I try to start a new or old 50g KML session the emulator will make a constant chirping sound but will not turn on until I close the session down. I assume the memory file has been corrupted, try to reset, replaced the rom file and Emu48.dll. Where is memory file? Is it hidden somewhere? Thank you. |
09-10-2021, 08:36 PM
(09-10-2021 08:58 AM)RPLman Wrote: Hi guys, Flashtools uses the virtual Saturn opcodes from the 49g+/50g. In theory it should work fine on Emu48+ with the service pack that enables emulation of the ARM models. It would not work well on the standard Emu48 as it simulates a standard Saturn. |
