What does G_0 mean when using desolve?
09-20-2021, 03:33 AM
Hi everyone,
I just started to learn calculus and I was using HP Prime to solve some differential equation with desolve. For example I entered following command: Code: desolve(d(y,x))=(y^2-4) ) Code: [(-2*G_0*e^(4*x)-2)/(G_0*e^(4*x)-1)] So what does G_0 mean? It doesn't look like 'y' or something.... |
09-20-2021, 04:35 AM
RE: What does G_0 mean when using desolve?
G_# refers to a constant. If you specified boundary conditions, you would get the result for those specific conditions as opposed to a constant covering a general solution.
09-20-2021, 01:33 PM
Note that integration also generate constant of integration.
But, if we use integrated result, F(x), to evaluate F(b) - F(a), the constant cancelled. Thus, HP Prime CAS (and many other CAS) did not return the constant. XCAS> ∫(x,x) → x^2/2 Although constant is not reported, keep in mind it is there ... |
