MAXON Motor
11-30-2021, 02:19 AM
MAXON Motor
Hi all,
With some card reader motors failing over time, I thought I would contact MAXON directly to see if there are any replacements available. Here is the reply... Code:
(This is the direct link to the motor shown in the data sheet) https://www.maxongroup.com/maxon/view/pr...x16/110069 cheers Tony |
11-30-2021, 06:28 PM
RE: MAXON Motor
I've actually had 2 of these motors apart, to clean the commutator and wire brushes. It's a big job drilling out pins etc, but it did work and the motors now work again.
If you've got a dead motor, give it a try. Nothing to lose. Regards, Dave |
