Solve app bug report
03-16-2022, 11:40 AM
(This post was last modified: 03-19-2022 01:30 PM by roadrunner.)
The solve app does strainge things when there are more than 12 variables.
This is on the emulator, 2.1.14592 Windows 10 version 1909 Here is an example: Reset the Solve App, then tap Start; Press escape, then go to the home environment; Copy and paste each of the 6 lines below into the home command line, press enter after each line: 'A=B+C+D'▶E1; 'B=C+D+E'▶E2; 'C=D+E+F'▶E3; 'D=E+F+G+H+I+J+K+L+M'▶E4; 0▶A▶B▶C▶D▶I▶J▶K▶L▶M; 1▶E▶F▶G▶H; Go to Symbolic view and check E1 thru E4; Go to Number view, check A thru D, uncheck E thru M (M is located on the second page) Tap Solve. M mysteriously checks itself and is solved for. Go back to page one and A is mysteriously unchecked. Check A, uncheck M, tap solve; and it repeats. The Solve app when equations have more than 12 variables does other weird things as well. See this thread for another example: https://www.hpmuseum.org/forum/thread-18102.html -road |
01-13-2023, 02:02 AM
RE: Solve app bug report
(03-16-2022 11:40 AM)roadrunner Wrote: ⋮ Thanks for posting. I managed to reproduce the problem here by following your nicely detailed instructions. So I filed a bug report for this on the bug tracking site I’ve set up. … and the bug got fixed! ![]() (If anyone reading this would like an account on the bug tracker I’ve set up to help organize matters, just let me know by PM.) |
