Unit conversions not possible in home mode
06-24-2022, 08:31 AM (This post was last modified: 06-24-2022 08:38 AM by Adiwa.)
Dear Forum
The examples show the possibility to convert units by the "convert"- command in home mode.
On my Prime I get a syntax error in home mode. I suppose it is, because I'm on RPN and so I can only write a semicolon and not a comma, as it is indicated in the examples. When I go to CAS, then I can do these conversions.
Is my appreciated RPN mode blocking me out of some functions in home mode?
Thanks for your replies
Adrian
06-24-2022, 08:57 AM
RE: Unit conversions not possible in home mode
In RPN mode you have to specify the number of parameters a function takes from the stack. For CONVERT it's 2:
06-25-2022, 06:35 AM
(06-24-2022 08:57 AM)Didier Lachieze Wrote:  In RPN mode you have to specify the number of parameters a function takes from the stack. For CONVERT it's 2:
Dear Didier
Thanks very much for your hint, I can do it now in home. The Prime is a very powerfull tool, but it's not a very intuitive tool.
Adrian
