(15C) Weibull Distribution Calculations
09-26-2022, 04:38 AM
The Weibull probability density distribution function is:
f(x) = (b / Θ) * (x / Θ)^(b-1) * exp(-(x / Θ)^b) with the lower tail cumulative distribution of (-∞ to x): Area = 1 - exp(-(x / Θ)^b) What follows are four calculations regarding the Weibull Distribution. In the following programs, store the following values first prior to running the programs: R0 = x R1 = b R2 = Θ Use whatever labels you like. HP 15C Program: Lower Tail Probability - Weibull Distribution CDF = 1 - exp(-(x/Θ)^b) Code: Keys: Example: b = 1.96, Θ = 420 x = 300, result: 0.4038 x = 400, result: 0.5970 x = 500, result: 0.7552 HP 15C Program: Failure Rate - Weibull Distribution FR = b/Θ * (x/Θ)^(b-1) Code: Keys: Example: b = 1.96, Θ = 420 x = 300, result: 0.0034 x = 400, result: 0.0045 x = 500, result: 0.0055 HP 15C Program: Mean of a Weibull Distribution µ = (1/b)! * Θ Code: Keys: Example: b = 1.96, Θ = 420 Result: 373.3720 HP 15C Program: Standard Deviation of a Weibull Distribution σ = Θ * √((2/b)! - (1/b)!^2) Code: Keys: Example: b = 1.96, Θ = 420 Result: 198.2208 Sources: HP55 Statistics Programs Hewlett Packard Company. Cupertino, CA. 1975 Ma, Dan. "The Weibull distribution" Topics in Actuarial Modeling. September 28, 2016. https://actuarialmodelingtopics.wordpres...tribution/ Last Retrieved September 20, 2022. |
