Installing CAS on calculators that do not support CAS
10-11-2022, 04:17 AM
I premise that I am new to this world that I am trying my hand at and should be a part of in the next few years.
I have a Casio fx-CG50 graphing calculator on which I have xCas installed .
However, I was looking for a program that would show me all the steps of solving various math problems (e.g., equations), as I believe a real cas is.
Is there by any chance any way to display the solving steps with xCas, otherwise is there any other program that has this function?
10-13-2022, 01:17 PM
RE: Installing CAS on calculators that do not support CAS
AFAIK, no cas shows the steps to solving a problem. They simply solve things symbolically as opposed to numerically.
10-13-2022, 05:14 PM
It is interesting that an early Casio CAS calculator, the Casio Algebra FX 2.0 Plus (the Plus indicated the CAS version), included an Algebra tutor menu option showing step-by-step solutions for some algebraic operations.
10-13-2022, 08:02 PM
(10-13-2022 01:17 PM)KeithB Wrote:  AFAIK, no cas shows the steps to solving a problem. They simply solve things symbolically as opposed to numerically.
What about the step-by-step option in the HP 49/50 CAS? It shows the result a step at a time, although it doesn't explain what rule was used at each step like some of the online services do.
— Ian Abbott
10-17-2022, 07:08 PM
HP-40gs offers step by step solution also - chapter 16 in the UG.
10-20-2022, 12:45 AM
I use Wolfram Alpha Pro - it does step by step workings - obviously it’s only used to check step workings agree with what you’ve already done by hand!
Denny Tuckerman
